a few ss4000E?s
Old Nov 24, 2003 | 04:03 PM
mccool98ta's Avatar
Default a few ss4000E?s
i recently ordered a ss4000 and when i opened the box today i realised that i was sent a ss4000E instead. would there be any problems installing this converter, such as the 6 bolt mounting instead of 3 bolts, my car is a 98. i do plan to add a power adder down the road and i know that it will be better for that, plus im not out any more money since i was charged for the regular ss4000
thanks
Jason
Old Nov 24, 2003 | 05:29 PM
Mekkadon's Avatar
thanks
Jason
you will need the 6 bolt flywheel.
Old Nov 24, 2003 | 07:37 PM
DMcRacer's Avatar
When I was changing from the Yank Stealth 2600 to the PY3800E I noticed a crack in the stock flywheel. I bought a heavier '98 model flywheel and drilled the extra 3 holes in it.
Old Nov 24, 2003 | 10:44 PM
mccool98ta's Avatar
so none of the stock flywheels have the 6 bolt holes already there, not sure if i should send back this converter and get the regular ss4000, this sucks!
Old Nov 25, 2003 | 12:03 AM
Colonel's Avatar
It's very easy to drill a few holes. That's what I did when I installed a 6-bolt converter in my '00. It takes a drill and about a minute. No big deal.
Old Nov 25, 2003 | 12:17 AM
Z-Rated's Avatar
I was always wondering if it was cool to drill into the flex plate. good to know
Old Nov 25, 2003 | 12:48 AM
Colonel's Avatar
It always worked just fine for me running 9s with a transbrake. Hey, someone drilled the original 3 holes, right? No difference.
Old Nov 25, 2003 | 03:30 PM
mccool98ta's Avatar
Thanks for the input everyone. do you happen to remember what size of threads need to be tapped into it, colonel. i just want to let the shop know as much as possible when i take it in. thanks
Old Nov 25, 2003 | 03:42 PM
Colonel's Avatar
It's not threaded. The converter is.
Old Nov 25, 2003 | 07:14 PM
mccool98ta's Avatar
I see that now, thanks Colonel. once i get it installed i will take a pic doing a burnout infront of the Kentucky Fried Chicken World Headquarters for ya. its right down the road.
