TransGo seperator plate
Hey guys,
I just got my TransGo seperator plate in and noticed on the instructions it says that they made the 2nd ,3rd,and 4th feed holes smaller.Wouldnt this weaken the shifts or make them slower/sloppier? I Dont want or need a slower shift so would it be wise to open them all to the reccomended .096 3rd feed hole size?
Hey guys,
I just got my TransGo separator plate in and noticed on the instructions it says that they made the 2nd ,3rd,and 4th feed holes smaller.Wouldnt this weaken the shifts or make them slower/sloppier? I Don't want or need a slower shift so would it be wise to open them all to the recommended .096 3rd feed hole size?
Ok . It was kinda weird the way they have it written on the paper. It says something about trying it out and seeing how you like it and that if desired i can drill them to match the plate.Just a little confused on it i guess. Ok so based on another recemedation is to enlarge the 3rd feed hole to .094 for better 3-4 clutch fluid. I just wsnt sure if it was at all optimal to do it to the rest of the feed holes.
Yep, you gotta match it up. My 3rd feed was drilled to .125 per Sonnax valve instructions. The transgo kit has you open it up to .093 or .101 for "full race".
