Gains with lockup switch on PT4400
Old Nov 29, 2003 | 11:38 AM
LS1 BU's Avatar
Default Gains with lockup switch on PT4400
I was thinking of installing a lockup switch on my PT4400. Is it worth and mph and et??
Old Nov 29, 2003 | 07:35 PM
onebadz's Avatar
Not sure about ET but I know its worth a 1-2 MPH. Good Luck
WeS
Old Nov 29, 2003 | 08:11 PM
LS1 BU's Avatar
I'm looking for mph and et. If people have done it and not pick up et it is not worth it to me.
Old Nov 29, 2003 | 09:33 PM
B18B1LS1's Avatar
On the motor I didn't really pick up anything, but I haven't tried it too many times. But on the bottle it makes a world of difference with that converter being so loose. I think it's going to depend a lot on your combo/ peak horsepower, gears, tire size, cam, etc...
Jeffrey
Old Nov 29, 2003 | 09:46 PM
BudH's Avatar
Jeffrey
At what speed/rpm do you lock up your converter for best results?
Old Nov 29, 2003 | 10:11 PM
Hugger SS's Avatar
I lock my PT 4200 at around 6200 in 3rd. Picks up about a tenth and 2 mph on average
Old Nov 29, 2003 | 10:17 PM
98sspullin'em's Avatar
do yall happen to want to sell those pt's??
Old Nov 30, 2003 | 10:17 AM
B18B1LS1's Avatar
My best results have came from locking my verter in 3rd a little over 100 mph. As far as my rpm, it's at ~6000, but most of my run is at ~6000 or over with that verter on the bottle anyway.
Jeffrey
Old Nov 30, 2003 | 03:46 PM
LS1 BU's Avatar
I tried a lockup switch on my pt4400 today. I let it shift inot 3rd and I locked it up at about 6000rpm. My rpms went all the way down to 5,000 rpm. I lost 2mph on that pass. That was the first and last time I tried the lockup switch.
Old Nov 30, 2003 | 04:09 PM
gator's 99TA's Avatar
i would lock up the convertor no lower than 6100-6200 otherwise it will BOG hard and loose the mph. i have seen too many guys lock up the convertor too early, esp on nitrous passes, and BAD results occured. i have done it too on motor and had no ET difference. just my .02
Old Dec 1, 2003 | 06:41 PM
Roger White's Avatar
Anyone else tried this, or is this something that works and no one tells you about it after you do it.....
Old Dec 2, 2003 | 09:20 AM
CamaroSS_2002's Avatar
The pt4400 already has the posi-lockup clutch, if your engine makes over 475lbs of torque it will lockup
from yank's website
PRO THRUSTER 4000, 4200, 4400, 4600 (245mm, Stall speed 4000 through 4600, Posi Lock-Up Clutch w/Kevlar Linings, lightweight billet cover, 2.2-2.7 STR)
Posi lock-up clutch:
Yank Converters has made a breakthrough with the Posi lock-up clutch. By placing proprietary bearings between the lock-up clutch and the housing, while utilizing the highest grade carbon ceramic or kevlar linings, the converter can actually lock-up under the high torque load of a power adder like nitrous oxide or a blower! This positive lock-up action takes place when the engine torque exceeds 475 lb. ft. This will give the racer torque to the tires, close to that of a manual transmission. This is a Yank exclusive!
Old Dec 2, 2003 | 05:06 PM
B18B1LS1's Avatar
Is this somethng new? My car makes ~600 rwtq and mine definately doesn't lock unless I make it.
Jeffrey
Old Dec 2, 2003 | 09:49 PM
Jeffrey
I dunno maybe?
Maybe Yank will chime in, I think maybe the older PT series doesn't have it or it is an option?
Old Dec 2, 2003 | 10:34 PM
Black Blown 02's Avatar
12 Second Truck Club
I'd also like to know about this feature
