new TC
Old Dec 1, 2003 | 11:29 PM
the1turkey's Avatar
Default new TC
I've never posted on these boards before i post on some other camaro boards but i hear these are alot more helpful and technical
i'm getting a TC soon and wanted to ask some questions i'm looking at the 3500 TCI but was wondering if this is going to be streetable in a car i drive every day and how the tranny is going to hold up its stock i drive a 98 z28 by the way my tranny shifts hard and is still in good shape form what i can tell except for some noise while shifting into reverse or drive from park is this normal
anyway is this a good choice in conveters, will i see some big gains from it (i have 2.73 grars at the moment if thats helps) is it streetable, is there any special care needed (i'm getting tranny a cooler with it) like different tranny fluid or anything
well thanks
Old Dec 2, 2003 | 12:00 AM
WILWAXU's Avatar
Not my first choice, but more than streetable. Old school converter rules don't apply to these cars. The 4L60E in these cars with lockup and torgue of the LS1 make larger converters very liveable on the street.
Old Dec 2, 2003 | 06:14 AM
Kevin Winstead's Avatar
the1turkey,
That's a good converter for an everyday driver. It's the same one that the Colonel was running in his everyday driver with the stock longblock. He ran 11.82 at a raceweight of 3550. I think you'll be happy with it.
Kevin
Old Dec 2, 2003 | 10:17 AM
Schwa's Avatar
Same converter I am running, and I drive 250 miles a week, mostly in town stoplight driving.
Times in Sig.
Old Dec 2, 2003 | 01:26 PM
jimmyblue's Avatar
Moderator
From the looks of TCI's web site, the lockup clutch is
the same material on the SSF3500 as my SF3000, so
I recommend that you stay with a Dexron ATF (or at
least avoid B&M fluid; see my tale of temporary woe).
The site says it's "carbon fiber" though at another time
I was told it's a carbon ceramic.
Old Dec 2, 2003 | 03:02 PM
onebadz's Avatar
I think you will like the converter, my car is my daily driver and I drive about 250 miles a week. You will absolutely love the converter for a street/strip converter.On the other hand you might want to look at a higher stall converter. I would recommend the Yank SS4000 or a PT4200 trust me once you drive a car with the TCI SSF 3500 you will want more and more stall. Good Luck
WeS
Old Dec 2, 2003 | 03:40 PM
Colonel's Avatar
The SSF3500 is an awesome daily driver converter with great track performance to boot. As was mentioned before, that converter and 3.23 gears netted me low 1.6 60 fts and 11.8s with an internally stock engine in a heavy car. I was VERY happy with that converter and I think you will be too. BTW, I ran F-type fluid with that converter for a little while and it worked great. No clutch problems at all.
Old Dec 2, 2003 | 04:12 PM
the1turkey's Avatar
thanks for taking the time to post replies
Old Dec 2, 2003 | 05:00 PM
onebadz's Avatar
No problem man just let us know how it turns out.
WeS
Old Dec 2, 2003 | 10:56 PM
koolrayz's Avatar
I have the TCI SSF and love it. I also have the 2.73 gears. you will want to add an aftermarket cooler. Also may want a shift kit or at least need to tune the shifting. I used my predator to raise pressure and reduce shift time. i got .7tenthsoff the quarter with this converter
Old Dec 5, 2003 | 05:50 PM
the1turkey's Avatar
do i need to delete torque manament when i have them install the TC i ordered today the guy at the speed shop said no but i heard it was a good idea but didn't want to waste 50 bucks if i didn't had
Old Dec 6, 2003 | 11:11 AM
koolrayz's Avatar
I forgot to mention The predator removed torque management also. I know the tuning made a big difference for me alot of people say you need the shift kit but im happy so for with just the tune in my car.
Old Dec 6, 2003 | 02:56 PM
the1turkey's Avatar
so has enyone not removed Torque management mabe i will just shell out the 50 bucks if its worth it
Old Dec 7, 2003 | 11:15 AM
onebadz's Avatar
I am currently having TM problems with my predator(I think thats what it is). I think this is a must when you get a converter. Good Luck
Wes
Old Dec 8, 2003 | 06:26 AM
I would recommend deleting TM while you're at it.
Kevin
