Tranny Cooling Times
Old Dec 3, 2003 | 08:27 PM
Jpr5690's Avatar
Default Tranny Cooling Times
I Now Theres Alot Of Varibles Involved But Ballpark In A 02 T\a With A4 Tranny With My Mods (keep In Mind 1900gvw Cooler) If Im Go Out And Pre-load And Drag A Qtr Or Two I Know My Tranny Is Gonna Be Heating Up But Roughly How Long Should I Wait Before Shutting Off My Car See Cauz Sometimes I Race On My Way Home But I Only Live Like 10 Miles From Home So Usally I Donthave Much Cool Down Time So I Try And Just Putt Arround To Give It Cooling Time But I Just Kinda Wanted To See If I Need To Wait A Long Time Or Just A Couple Of Mins.... Any Suggestions Would Help Yes I Know I Should Buy A Temp Gage Which I Will Sometime In The Future.... Thanks
Old Dec 5, 2003 | 12:27 PM
A BAD T/A's Avatar
Thumbs up
I suggest a "Maxi-cool" type of kit which has its own temp controlled cooling fan to move air through the cooler even when stopped and idling.
See Summit or Jegs
You typed 1900gvw cooler, I assume you meant 19000gvw.
Old Dec 5, 2003 | 05:19 PM
Jpr5690's Avatar
Thanks,
Anyone Got An Idea On Cooling Times?
Old Dec 8, 2003 | 09:35 AM
A BAD T/A's Avatar
Cooling time is a factor of cooling efficiency. Put on a temp gauge to know for sure. A cooler with a fan, as described above, is gonna cool quicker than any thing less than 60mph down the highway!
And... if you are a serious racer, get the maxicool 24,000(?) gvw and bypass the one in the radiator.
Old Dec 8, 2003 | 02:39 PM
Jpr5690's Avatar
anyone wanna throw out a number for a car sitting in the driveway or putting round like 30-40 mph after a run or two ... a guess??
Old Dec 8, 2003 | 08:11 PM
Pete2k_Z28's Avatar
Cooling time is a matter of efficency as stated, AND ambient temperature. A trans will take longer to cool in Florida than up here in the cold white north. Also, the location of your cooler makes a difference, so it's impossible to say.
Best bet is get a trans temp gauge and/or AutoTap. As long as you're under 200 degrees F you're fine.
Old Dec 8, 2003 | 11:42 PM
Jpr5690's Avatar
geez no luck with this one well how about this if you had my car and just got odne raceing a few times how long would you wait before cutting off to feel safe that your not shutting it down too hot...... i understand its aguess but theres gotta be some sort of ballpark consenus
Old Dec 9, 2003 | 02:11 AM
Pete2k_Z28's Avatar
If it was YOUR car and not mine?
Just kidding.
I've found in warmer weather (before I had my cooler) that after a 1/4 mile run, on spray, and after sitting in the lanes for 5-10 minutes idling, my trans temps can reach over 200 degrees.
In all honesty you will probably find your trans will cool faster crusing around doing normal driving than letting the car idle. There's not enough fluid circulation or airflow over the cooler and radiator standing still.
At least that's been my experience.
Old Dec 9, 2003 | 10:03 PM
Jpr5690's Avatar
thanks
Old Dec 10, 2003 | 11:01 AM
foff667's Avatar
LS1TECH Sponsor
i agree...were not talking about a turbo here...idling makes my car heat up much faster than driving at a constant speed...also keep in mind you can easily heat soak a tranny...so the longer you drive the hotter the tranny gets...i can drive for an hour an dnot see my tranny temps go above 160 but once i shut it down in the lanes and start it up 1/2 hour later it will be at 190 from heat soaking.
lata
Bill
Old Dec 10, 2003 | 01:40 PM
Jpr5690's Avatar
okay so what do you do just shut it off even right after a run? i mean im tring to prevent damage by shutting down a hot tranny, is this even a prob or what ??? hell what do most do when they run do they shut it off right after ive always crused arround a it just to let things cool down before shutting it off
Old Dec 10, 2003 | 07:24 PM
Ragtop 99's Avatar
At a steady 60 mph in 4th gear locked, my tranny will drop 10* in a few miles or so in cool weather, depending on how hot is was.
Old Dec 11, 2003 | 10:33 AM
Jpr5690's Avatar
thanks!!!!!!! so ya think crusing like 5 miles after a run would be sufficent?
Old Dec 11, 2003 | 12:06 PM
Ragtop 99's Avatar
With a big cooler and 160 T-Stat you should drop right on down except on a summer day.
Old Dec 11, 2003 | 03:12 PM
Jpr5690's Avatar
ok great so like 5 miles at like 50 mph on at 75 deg day be sufficent????? and god dam how u get so many posts!!! its taken me foreven to get to where i am now you must type like 5 times more than i do...
Old Dec 11, 2003 | 05:44 PM
Ragtop 99's Avatar
Post count is pretty high. I've been here since the first week the site went live. Not all posts require long responses. sometimes it is just a simple "congrats" to someone who posted a new best in drag racing.
Old Dec 12, 2003 | 11:06 AM
Jpr5690's Avatar
ah i see well anayaws thanks for the help
another question have you ever used the g-tech comp cause i cant seem to get a good hp reading out of it it was tring tell me i had 247 hp when i dynoed 330rwhp and i know i can be losing tha much to other misc things like drag i was expecting like 300 which seems reasonable for othewrs using it but for some reason im not getting it .... im thinking it has to do with the procedure for measuring being semi-difficult to do in a auto car and mabye im not doing it right ???
Old Dec 12, 2003 | 11:51 AM
Ragtop 99's Avatar
It is rare that I have seen anyone get reliable, truly useful, information from a G-Tech. I put it in the toy catagory. Use a dyno or track times to guage where your car is.
Old Dec 12, 2003 | 01:43 PM
Jpr5690's Avatar
well that blows ! all well ill keep on chugin and see what i come up with
Jpr5690's Avatar
hey is 600 posts an new title?
