Time for a new converter?
Old Nov 7, 2009 | 05:55 PM
MYSTIC-1SC's Avatar
Default Time for a new converter?
ok well I currently have a 3600 stall, and am needing to know what you guys recommend for my current setup. I have bolt ons, Ms3 cam on 112lsa, 3.73 gears, and spray. I plan on spraying in the 125 to 150 range. future plans include prc 2.5 5.3 heads and fast 90 setup. I have been told to step up to a stall in the 4400 range to really take advantage of the ms3s power range. Let me know what you guys recommend. I can get the raceweight of the car with me in it if someone needs to know.
Old Nov 7, 2009 | 06:40 PM
01ssreda4's Avatar
to my understanding you dont want to run a 4K+ with nitrous bc it will "push through" the converter. Call up the converter sponsors and see what they recommend.
Old Nov 7, 2009 | 06:50 PM
1BAD_LS1's Avatar
Restricted User
Lower stalls with boost and nitruos and higher with NA setups.... the way i understand anyway
Deffinetally talk to whoever made your stall and they will get you setup!
Old Nov 8, 2009 | 12:09 AM
kinglt-1's Avatar
Contact greg at FTI! I recently purchased his 3800 w/ a 2.1 str, spec'd for spray! I have not had a chance to install it yet, so results are awaiting till next spring. From what I hear its a badass converter on the jug tho...
Old Nov 8, 2009 | 01:00 PM
MYSTIC-1SC's Avatar
thanks for the advice guys. I really would like to step up to something above the 4000 range built for the spray maybe a vendor could chime in and give me some direction.
Old Nov 8, 2009 | 01:10 PM
99Hawk262's Avatar
Talk to Chris at Circle D....he has a 4500 converter that can be sprayed I believe. Also, Yank's SS series would do the trick. I've seen an SS4200 that did well on spray.
Old Nov 8, 2009 | 01:50 PM
1BAD_LS1's Avatar
Restricted User
more specs on your current stall? Because if you spray on it it may become a 4400 stall, lmao!
Old Nov 8, 2009 | 02:04 PM
FiFdYnUtz's Avatar
i have friends who spray on 4400's and 4000's and they both run in the 9's
Old Nov 8, 2009 | 02:11 PM
eric01ss's Avatar
get you a circle d or yank ss4000
