Close up pics of lokar 36 inch 4l80 dipstick in car
I bought the 24 inch one by accident. It works but sucks..Had to cut bit off end of the dipstick so can get it in and out. You can fill if you use a long tube to funnel setup and checking is pain as well with it so far under the firewalll. Now have the longer 36 inch one to install. Just wondering if anyone has any pics of the 36 inch one in their car and where if anywhere were you able to fasten it to?
I have the 36" and you can mount it under the cowl were your AC unit is, or in that area. Raise the plastic cover that's around your wipers and dill two holes in the cowl under the windshield. It plenty long enough . I tried the 24" and said no way. Get the 36" and you will be set.
