B&M Hammer install pics
Old Dec 11, 2003 | 10:07 PM
kp's Avatar
kp
Default B&M Hammer install pics
Didnt finish putting the cable on but here is a few pics of a B&M Hammer I installed tonight. I have seen a couple other pics but figured it may help someone out..
I just roughly traced the shift boot onto a piece of 1/8" aluminum plate I had laying around, cut it with a jigsaw and bolted it down. Massaged the the ends with a hammer and there is very little gap, nothing a little silicone from underneath cant handle. Had to space up the rear quie a bit and trim off the mounting tabs for the plastic cover that comes with the shifter (see pics). Looks pretty nice and seems to work well - i'll find out when I get the TH350 in..
Old Dec 11, 2003 | 10:21 PM
Cummins's Avatar
Looks Nice!
Old Dec 12, 2003 | 06:15 AM
4thGENRETARD's Avatar
Nice one, I'm drooling. Good show man.
Old Dec 14, 2003 | 07:31 PM
silverTA's Avatar
whay u cuts some parts of the shifter
Old Dec 14, 2003 | 07:52 PM
BlackWS602's Avatar
Looks very nice. Can something like this be done with the 4L60E?
Old Dec 14, 2003 | 09:33 PM
kp's Avatar
kp
The shifter works for powerglides and 4 speed autos so yes it will work with a 4L60.
The tabs that were cut were to mount the little plastic console B&M gives you. The boot wont sit flush in the front if you dont cut the front one and the ashtray wont open if you dont cut the rear one. Maybe if it was mounted a little different you wouldnt have to cut them but they really serve no purpose for this application..
Old Dec 14, 2003 | 10:47 PM
onebadz's Avatar
Looks good, great work.
Wes
Old Dec 14, 2003 | 11:28 PM
BlackWS602's Avatar
Well I've found my next mod then
Old Dec 15, 2003 | 08:35 PM
DOC OTIS's Avatar
Great info. Thanks for the pics. Getting ready to do the same install. Except I am going to modify the stock M6 shifter handle instead of using the t-handle.
Old Dec 15, 2003 | 09:45 PM
Jorday's Avatar
Looks good, man.
Old Dec 15, 2003 | 10:05 PM
kp's Avatar
kp
I'm not too fond of the stock Hammer handle but it works, I'll probably end up putting a ball on it..
