Trans. lines for a th350
Old Dec 7, 2009 | 06:16 PM
1mean96ss's Avatar
Default Trans. lines for a th350
What did you guys use for trans. lines on your th350's. braided lines, steel lines that you bent. And if you have pics or part numbers for braided lines and fittings post them.
Old Dec 8, 2009 | 12:25 PM
supermouse4's Avatar
Solid steel lines is what I always use. Not sure of your application, but you could always search Jegs or Summit or perform a google search for finding braided or solid lines for your TH350.
Here is a stainless steel braided line kit from Jegs:
http://www.jegs.com/i/JEGS/555/60366/10002/-1?CT=999
Old Dec 8, 2009 | 02:49 PM
BrianEsser76's Avatar
I just buy straight sticks of 3/8" or 1/2" and bend it myself.
Old Dec 8, 2009 | 03:06 PM
382ssz28's Avatar
Most trans shops carry the 5/16"X60" straight easy bend lines for 10.00-12.00 per line. You can go fancy with the braided stuff with the -6AN case fittings. Many of the older Jeep Cherokee or Cadillac 400 trannies have the larger 3/8" case fittings that will fit the 350 trans for larger 3/8" line diameter.
Old Dec 8, 2009 | 04:04 PM
OUCH. Most parts stores have the aluminized sticks for $7 for a 60" piece of 5/16" or 3/8".
Old Dec 8, 2009 | 05:07 PM
cambirdracing's Avatar
I run the 3/8 "brake line" from the auto parts store and hook each end up with -6 steel braided. Never had a problem. Been this way since 96.
Old Dec 8, 2009 | 05:10 PM
bad6as's Avatar
whats the threD SIZE on a th400 for the inlet and outlet for lines
Old Dec 8, 2009 | 06:26 PM
1mean96ss's Avatar
Thanks for the link on Jegs, most likely what ill be doing that way i can keep them along the frame rails.
Old Dec 8, 2009 | 06:45 PM
1mean96ss's Avatar
What tranny mounts are you guys using for the th350 ?
Old Dec 8, 2009 | 10:23 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I've also got the "brake line" on my car. A friend used braided line and AN fittings on his and looks awesome. I'll be making the switch to braided next year.
FWIW: I'm running a poly mount with my TH350
Old Dec 9, 2009 | 03:01 PM
1mean96ss's Avatar
what kind of poly mount ? part #
Old Dec 10, 2009 | 01:18 AM
Z28/2002's Avatar
Don't remember the part number but I got it for a TH350. I think it is a Prothane
Old Jan 22, 2010 | 03:07 PM
Ego Killer's Avatar
it cost a little extra but I used -6 braided. and thats what Ill do next time
