No WOT Downshift from 3rd
Old Dec 17, 2003 | 08:21 AM
SS891's Avatar
Default No WOT Downshift from 3rd
I installed the GM hotcam over a weekend a couple of weeks ago. Install went well. Installed the new Predator tune from James at RWTD. Ever since that weekend, I have a issue that I can not come up with an answer on. (99 SS a4)
From a stop, 1/4 accel, vehicle shifts rapidly 1,2,3 before 30mph, then If i go WOT, vehicle stays in 3rd for about 3 seconds Then it will jump into 2nd. After doing some logging of this event,
The only thing i saw was 4.3 volts at tps, 26mph in 4th gear at 1350 rpms. Stays this way for about 9 frames, then finally goes into second gear. No getting any slippage, feels like a M6 in 6th gear at 40 mph when you go WOT, just boggs down.
This also happens with a stock tune. Seems like it happens more if im in drive and not Overdrive, but i wouldnt think that would matter...
any ideas?
Old Dec 18, 2003 | 10:26 AM
SS891's Avatar
any ideas?
bumpity bump
Old Dec 19, 2003 | 08:51 AM
Derek98z's Avatar
Only changes were cam and tune? Sounds like the shift map is wrong.
Old Dec 29, 2003 | 01:53 PM
SS891's Avatar
Well.. im still having this battle. I have replaced the PCM, TPS cleaned the MAF.. Still have the same problem.
