ms4=? stall
Old Jan 8, 2010 | 12:49 PM
TermnEatr's Avatar
Default ms4=? stall
wat stall for a ms4?
Old Jan 8, 2010 | 01:23 PM
Ls1Rook's Avatar
n/a 4k+ nos 4k or less
Old Jan 8, 2010 | 01:27 PM
mikefirehawk0623's Avatar
yank 4000ss
Old Jan 8, 2010 | 01:29 PM
01ssreda4's Avatar
Old Jan 8, 2010 | 02:52 PM
SSmoken's Avatar
atleast four thousand
Old Jan 8, 2010 | 03:56 PM
TermnEatr's Avatar
thanks guys appreciate the info
Old Jan 8, 2010 | 11:56 PM
383lt1impala's Avatar
If its strip only 5000+ tsp camaro is 6000 I believe.
Old Jan 9, 2010 | 02:56 AM
TurboAv's Avatar
I say 4500 or more. Give Greg at FTI a call.
Old Jan 9, 2010 | 10:50 AM
Circle-D's Avatar
I would suggest 2 options for you.
The first would be our 245mm 5C rated at about 4200-4400. It will have some amazing 60's, hold on tight . It is still very street-able, I have a lot of guys running this converter and put a lot of street miles on it.
Second option is our new 230mm, I would build it somewhere around 4500-5000, need more specifics on your build. This would be a max effort setup. Still great 60's and amazing top end as well. It is street-able, but not a good option if your are building a street car.
Just depends on what your goals are, track queen or street/strip car. I would be happy to discuss these options further. If you want to give me a call we can go over your car details and select the best combo. You can also go on my website and fill out the "Ask Chris" page to get me the car details and I will get back to you.
Chris
Old Jan 10, 2010 | 07:10 AM
LS69TA's Avatar
Chris
Not to hijack the thread, but I'm kinda in the same ballpark. The engine will more than likely be a iron 408 with a cam in the 245/255 .650ish lift on a 110/111 but may change cam size some if I put a F1 Procharger on it down the road. It won't be an all out strip car, but will see some street miles a day or 2 a week maybe. Which do you think would be the best way to go?
Old Jan 10, 2010 | 04:04 PM
Circle-D's Avatar
Quick answer is we need to know if you are adding the F1 or not. Huge difference on which converter we go with. You can shoot me a PM to discuss further. Or give me a call at the shop.
Chris
Old Jan 10, 2010 | 09:26 PM
Minshall's Avatar
Ive got the LG G5X4 cam and the Circle D 5C converter. Chris is right on the money with the 60fts. 1.42s all day long for me and the street manners are great. Cant go wrong with Circle D.
Old Jan 10, 2010 | 10:34 PM
TXZ28LS1's Avatar
with a cam that big of the MS4 i would do a minimum of 4000 stall. DO NOT GO CHEAP ON A CONVERTER!!! run the proven stalls like circle d or yank!
Old Jan 12, 2010 | 09:52 AM
LS69TA's Avatar
Chris
Chris, I think for the time being unless I can afford the F1 at the same time as the build, it'll probably be N/A for a while. Probably stay around 9:1 cr for when I do eventually put the blower on it. I'll definately be in touch once I get everything started and begin the build.
