A-4 has flywheel or flexplate
Old Dec 19, 2003 | 02:16 PM
VietRacingGuy's Avatar
Default A-4 has flywheel or flexplate
i kinda confuse,
automatic trans. has flywheel or flexplate?
SLP sell aluminum fly wheel for LS1 with automatic trans. 2 tenth a second 1/4 mile time faster.
Old Dec 19, 2003 | 02:48 PM
93LS1RX7's Avatar
All autos use a flexplate but some people refer to them as a flywheel.
Auto=flexplate
manual=flywheel
Old Dec 19, 2003 | 03:08 PM
BigPlanTransAm's Avatar
what is the difference?
Old Dec 19, 2003 | 04:47 PM
Xsta Z 28's Avatar
The flex plate is basically a heavy gauge sheet metal disc (typically balanced) with a ring of teeth welded on, around the perimeter for starting.
A flywheel is a heavy chunk of typically cast metal that acts as the contact surface of the manual clutch similar to a brake rotor, but also has the teeth around the perimeter for starting the car.
Kind of a crued answer but I think it works.
Old Dec 19, 2003 | 05:14 PM
SteveC's Avatar
From: Poway, Ca. where GOD and the sun always shines
Smile
Another common name for the flexplate is a "mating ring".
SteveC
Old Dec 19, 2003 | 06:22 PM
so if i want to buy light weight fly wheel for my automatic z28, then i should tell the seller i need the flex plate, right?
Old Dec 19, 2003 | 06:33 PM
WicketMike's Avatar
alot of people call a flywheel a flexplate and vice versa
Old Dec 19, 2003 | 06:39 PM
Jpr5690's Avatar
i think theyalso offer the a flex plate but i think what their tring to say is your car has a flex plate instead of a flywheel so you would wanna order a new flex plate not a new fly wheel...... keep in mind the install is gonna cost a few bux for that .. unless youve done everything else why dont you do a cam or some headders or something less labor intensive thats gonna be big $$ for little gain form what i hear
Old Dec 20, 2003 | 05:13 AM
Jammer's Avatar
Can a flex plate really make a difference folks?
Old Dec 20, 2003 | 08:33 AM
SteveC's Avatar
I would not purchase the 2001 & 2002 flexplates, they are thinner, and have a tendency to crack, Here is the ticket: Go to the top right blue column and click on "SFI Flexplates"
http://www.thunderracing.com/index.c...ategoryid=1081
SteveC
Old Dec 25, 2003 | 03:30 PM
Gen3Benz's Avatar
i agree with jpr, spend your money elsewhere.....but if your gonna yank the trans get a higher stall converter and you wont need the extra horsepower to go faster.
the lighter flexplate will allow your engine to spin quicker, just do both
