Looking for stall recommendation please
Old Jan 10, 2010 | 07:29 AM
MUSTANGBRKR02's Avatar
Default Looking for stall recommendation please
I have a 02 TA with a 4l80e. Car has T70 turbo with about 9lbs. 232/234 113 cam and a stock 3.23 gear.
Old Jan 10, 2010 | 09:28 AM
GregWS6&z28's Avatar
Give Greg @ FTI a ring. FTiCONVERTERS on here. he will get you staight. The stalls are built to handle some major power.
Old Jan 10, 2010 | 10:47 AM
novaflash2002's Avatar
i would stick around the 3200- 3600 range if it was my car.
Old Jan 10, 2010 | 11:54 AM
Yank's Avatar
Call me we have some real fast cars running this setup with our converter
look at this.
http://www.converter.cc/testimonials/david/
Dave or Mike at 775 826 9955
Old Jan 10, 2010 | 11:59 AM
What would be the price of that converter Yank? Around 950 or so plus shipping?
Old Jan 10, 2010 | 12:03 PM
sdotlog's Avatar
look at this.
That car is bad ***...
Old Jan 10, 2010 | 04:01 PM
Circle-D's Avatar
I would suggest a multi disk for anything FI. That gives you the ability to lock up at WOT in the 1/4. We just happen to make a custom billet multi disk that is designed to handle your power levels. Good choice on the 4L80e, at your numbers it is a necessity. Going to need a 258mm style converter, probably something in the 3500 range. Would need a little more specifics on the setup to give an exact recommendation. Please give me a call or you can fill out the Ask Chris form on my website and I will get back to you.
Chris
