4l60e rebuild
Old Jan 11, 2010 | 12:34 PM
BlackBirdRyder02's Avatar
Default 4l60e rebuild
hey iam going to have a stall 2800-3000 installed in my tranny but somebody told me to rebuild it first. now hears the confusion the first thang is one guy said to just replace the beast shell and the servo and ill be fine. and there person said he has the kit for 500 and thats what i need. and one person said just throw the stall in. now i dont see the track of race like talking about it but will get down if i have to what should i do ppl help.
Old Jan 11, 2010 | 03:24 PM
anybody
Old Jan 11, 2010 | 08:09 PM
Circa307's Avatar
ya im kinda wondering the same thing b4 i install my ss4k stall. Anyone???? free bump btw
Old Jan 11, 2010 | 08:36 PM
Quick_Z's Avatar
Never herd of having to rebuild the trans before a converter install, unless its slipping bad or something like that, but i would have a shift kit installed and a tranny cooler if you don't already have one, just my .02 cents.
Old Jan 11, 2010 | 08:49 PM
Circa307's Avatar
tranny cooler for sure. but if the tranny front pump goes out will it not take out the stall converter?
Old Jan 11, 2010 | 11:45 PM
hmm good one well im just gonna put the converter in because i already have a tranny cooler installed
Old Jan 12, 2010 | 07:01 PM
so just change the beast shell and the corvette servo and put a shift kit in it?
Old Jan 12, 2010 | 07:04 PM
wait i have a 02 t/a so mines is kina strong already sooo imma just put the shift kit in
Old Jan 12, 2010 | 07:48 PM
gm02ceta's Avatar
What brand shift kit you going with?
Old Jan 12, 2010 | 09:17 PM
69chvl468's Avatar
Most of those 4l60's 98-02, in the camaro's and TA's have a corvette servo piston already. Both of mine did. check it first before you buy one....
Old Jan 12, 2010 | 09:36 PM
jman54002's Avatar
I install my 3600 stall on my stock 02 trans 4l60e, then installed a HD2 shift kit, worked great. Plus I spray 150 shot. so far so good. Cooler needs to be installed for sure shift kit is just some added help. Plus you will need the tune changed for the stall they say but I haven't done it yet. I would check with a tuner to be sure on that. andhave fun the stall is one of the best mods...well unless you have N20
Old Jan 13, 2010 | 12:19 AM
lol i have the trans go hd2 kit well thts that imma put the stall in then
Old Jan 14, 2010 | 10:41 AM
i had asked these questios too because my friend always listin to this mr know it all saying if we just just the stall in with out getting it rebuilt it'll blow this true?
Old Jan 14, 2010 | 01:55 PM
Circa307's Avatar
if it aint broke dont fix it. when it does break fix it better than b4. thats my moto with my new stall going in within next couple weeks.
Old Jan 14, 2010 | 03:07 PM
Default right
and ya right too because ya never know youll probaby last fa ages with the stock one plus he dont really race it any way except street wise lol
Old Nov 12, 2010 | 09:27 AM
hawk2002's Avatar
my car has 107000 miles on it its a 02 t/a no tranny problems wit a cooler on it can i still put the stall in
Old Nov 12, 2010 | 08:30 PM
ericwilloughby's Avatar
The beast is just the name brand of the HD sun shell. My trans has been out 3 times this year. Twice for the 3-4 clutch pack and a broken input sprag. Damn race track and hard shifts dont mix well. This last time i wanted it to last so i went all out with all the good hard parts. Cost me double what i paid last time and the 3-4 pack slipped on the first day.
Just put the stall in and fix issues as they come up.
Old Nov 14, 2010 | 02:59 AM
hawk2002's Avatar
ok that'll work
Old Nov 14, 2010 | 09:36 AM
hawk2002's Avatar
but so far the main things iam hearing to replace is the beast shell, the clutches, and bands . also is the z pack the best clutches?
Old Nov 14, 2010 | 11:52 AM
Predator T/A's Avatar
no the z-pack has its place in a trans but not in a performance unit you would be better off with the stock 6 clutches with clearnce set right however you can put 8 stock HE frictions in the drum by either using the thin 4l65e clutches and the stock thickness steels or you can use the stock thickness clutches and thin steel. The stock BW HE clutches are fine you just need more of them. However between the z-pack and the stock 6 I would choose the stock 6 with tight clearnce. with the stall you will want to remove the checkball from the input shaft this will help the smaller clutch apply better. you also want to have the PWM lockup removed either with tuning or mechanically. The transgo HD2 kit has a valve that does this also.
