4000+ stall owners...Need tuning advice
Old Dec 20, 2003 | 05:40 PM
BADFNZ's Avatar
Default 4000+ stall owners...Need tuning advice
I just put in my PT4400. This converter rocks I'm on 3.23's and it's not too loose for me but my pcm is tuned for a 3500 so I obviously have some tweaking to do. My lockup is set at 47 mph now at partial throttle but I'm thinking of lowering this so I'm not driving around town at 2700. I'm also planning on bumping the line pressure up a bit because I can't even feel my shifts.
Can you guys give me some of your settings on line pressure, lock up, partial throttle shift points, etc. Or anything that will make it a tad more drivable.
Old Dec 20, 2003 | 06:05 PM
Ragtop 99's Avatar
Raise all your part throttle shifts between 6% and 50%:
1-2 +2 mph
2-3 +3 mph
3-4 +4 mph
You can tweak them after you drive around bit on those settings.
I keep it in D around town. Have it Lock up between 30 - 35, pretty much as soon as you shift into 3rd.
Old Dec 20, 2003 | 06:33 PM
BADFNZ's Avatar
Thanks, I'll try that
Do you get any cam surge from that low of a lockup?
Old Dec 21, 2003 | 03:12 PM
BADFNZ's Avatar
Anyone else?
Old Dec 21, 2003 | 04:00 PM
Jorday's Avatar
With my car I did pretty much what Ragtop just said. However I sometimes don't use D around town because the cam surge in my car gets pretty nasty at times.
Old Dec 22, 2003 | 02:50 PM
Colonel's Avatar
When I get a chance I'm going to make a detailed thread of the things I've done to tame my SS4000. I played with it ALOT before I got it just like I want it.
Old Dec 22, 2003 | 04:07 PM
02redSS's Avatar
that would be great as I am looking for the same advice.
thanks
Old Dec 22, 2003 | 04:33 PM
BADFNZ's Avatar
That would be great
I've been driving around in 3rd now instead of OD and it makes a hell of a difference. Instead of needing 47 or to so lock up, it does it right at 35. I still need to mess with the partial throttle shifts and line pressure.
Old Dec 24, 2003 | 08:55 AM
Humanoid's Avatar
Colonel,
I would really benifit from that list as I am having the SS4000 put in my car on Jan 2.
Thanks
Hugh
Old Dec 24, 2003 | 09:32 AM
Ragtop 99's Avatar
Colonel's post will be informative but remember what works for one person is not perfect for the next. A 4000 stall is not magic. Some people think it is loose; others think it is no big deal. Different cams, gears, and driving styles means you should really experiment with your settings. That's why I give starting point suggestions.
I drove around with ATAP displaying speed and TPS to see at what TPS and speed I wanted the converter to lock at, and what speed/TPS I want downshifts to occur at. For example, at more than 33% TPS I want the car to downshift out of 4th to 3rd at speeds below 60 mph. Just take a drive and make some mental notes and experiment.
Old Dec 24, 2003 | 07:03 PM
Jorday's Avatar
Yah, that's true for sure. I don't think my 4200 is all that unstreetable. It's hardcore, but I drove her everywhere for quite a while and it didn't bother me really. Yet, I have my friends tell me that they would never be able to tolerate the converter being that loose in thier cars.
Old Dec 31, 2003 | 06:12 PM
2001 Red Coupe Bandit's Avatar
i have an SS4000 in my Vette it is pretty Tight but I am gonna tweak the driveability issues with LS1 Edit. Had an SS3600 before it is looser than that for sure, but not too bad.
The Bandit.........................
Old Dec 31, 2003 | 06:23 PM
Colonel's Avatar
Sorry I'm being so slow about giving my programming details but this is something I want to really explain in detail. Gotta be in the right mood (lot's of coffee and nothing better to do.)
Like Ragtop said though, my setting will not be the best for everyone, or even most people, but they will give you a good idea of what to change and how to change it. Your preferences, converter, gearing, and cam selection may make your best programming a little, or alot, different than mine.
