Car dies when put into D and R.
Old Feb 1, 2010 | 05:57 PM
crAzy95Z28's Avatar
Ok i have some other news i didnt know. He is telling me he can start the car in N, but when he puts his foot on the brake and go into D it dies. I asked him if he could just start the car in N and pop it into D without hitting the brake without it dying. He says yes, but as soon he applies the brake the car dies. Same goes with starting in P and going into R.
Could this still either be the stall or the lockout solenoid or something else?
Old Feb 2, 2010 | 11:55 AM
AutomagicLS1's Avatar
Originally Posted by crAzy95Z28
Its been tuned. Its not a tuning issue.
Have your tooner hook a laptop up to that car and log to see if the car is commanding lockup in the converter
Old Feb 2, 2010 | 12:49 PM
slow67's Avatar
Gingervitis Addict
If it seems solely brake pedal related, the diaphragm on the brake booster could be blown/leaking.
Old Feb 2, 2010 | 01:27 PM
crAzy95Z28's Avatar
Wouldn't it have the same problem when it's in P or N if the brake booster is blown/leaking?
Old Feb 2, 2010 | 01:59 PM
slow67's Avatar
Gingervitis Addict
Yes it would. You said if he goes from P>R or N>D without pressing the brake its no issue.
Old Feb 2, 2010 | 02:17 PM
crAzy95Z28's Avatar
Yes, but what i was saying wouldn't it stall out if he was in P or N when pressing the brake if the brake booster was broken/leaking? He can rev the car perfectly fine in P or N.
Old Feb 2, 2010 | 04:13 PM
slow67's Avatar
Gingervitis Addict
Depends. In the car I had trouble with, you could rev it and you couldn't even tell it had a vacuum leak until it tried to idle. And it was carbureted. It was a stick though. It did stumble some under a load (ie, in gear moving) until it got higher in the rev range.
An easy test is to block off the brake booster (large bolt with a hose clamp) and test. Just remember your brake pedal will be hard as a rock until you plug it back in.
Old Feb 3, 2010 | 04:10 PM
crAzy95Z28's Avatar
Ok, we just jacked up the rear of the car to get the rear wheels off the ground. We started the car and put the car in N. Applied the brake and shifted into D. The tires started to spin. We pressed the brakes and the wheels slightly came to a stop, but the wheels still spun slowly. Now we did it again but applied the E brake while in D. The wheels came to a complete stop and the car died.
So what does this mean?
Old Feb 5, 2010 | 01:06 PM
crAzy95Z28's Avatar
Well he took it in and it ended up being the lock up solenoid.
Old Feb 5, 2010 | 04:52 PM
Ls1N20's Avatar
See, thats what you shoulda done in the first place lol. If it's fine in park and nuetral it isn't a tune related problem.
Old Feb 6, 2010 | 01:48 AM
archerandsons's Avatar
i hate car that do this. i now i a lil gas get a guy i know had that did same thing, but i dont know if he fixed it or not....
Old Feb 6, 2010 | 11:01 AM
  #32
382ssz28's Avatar
Talking
You're welcome...
