? About Tranny Temps!
Some people use additives (ie LubeGard) with good results. Although there is no replacement for a proper spec synthetic atf. The issue with most additives is that you are still stuck with an inferior base oil (ie conventional atf is most times group II/+. If draining at proper intervals you will more than likely never see any issues. But with a synthetic you get twice the intervals in most applications with much improved thermal capabilities. Like they say, there is more than one way to skin a cat.
People need to understand that the most important thing when talking about ATF is that the spec is correct. I have been running top of the line order only synthetic fluids in my cars, trucks and drag cars for going on 16 years. Never one lube related failure! Synthetic ATF is not a magic fluid, it just simply outperforms conventional ATF, period. There is no comparison. There are countless fleet vehicles that have the 4L60e that have logged over 200k on synthetic atf without issue. And the 4L60 is a crappy transmission. I have 210k on a 92 suburban running synthetic atf since 60K. Shifts like new. My opinion is that people just "happen to be" running synthetic atf and beating the **** out of their cars drag racing and something breaks. I really doubt anyone on here has proven a lube related failure alone, as most don't even know what PCMO or group III means!
Alot of folks here need to eduacate themselves on lubricants. Just because you can turn a wrench does not qualify you to speak about lubricants. When I hear people in these threads talking about ATF and the first thing they say is "they contain a ultra high amount of detergents blah blah" I just want to scream. End of rant. The Best V8 Stories One Small Block at Time
The filter has no influence on how the atf will act in the transmisson. That is affected by the FM's(friction modifiers) and viscosity of the fluid mainly. For example Dexron III( no longer licensed or used by GM) has a viscosity at 100 degrees celcius of 7.5-7.8 for most. Take Gm's newest addition, Dexron VI with a viscosity of around in the high 5's, low 6's and with a different additive package(levels of friction modifiers etc). When placed in a trans that was originally spec'd for Dex III often times the transmission may exhibit different behaviour. Now does this mean its bad, no it all depends. If its in good working order the Dex VI should work better than the that of Dex III in a stock application! Now add some power and everything changes.
Like I have stated before, pick a fluid that meets the spec. I prefer Dex III synthetic atf(redline D4). I like the fact that it is a higher viscosity fluid and just might protect better. Plus it meets the transmissions viscosity requirement.
Quickly. Dexron III works like this. It starts out with a viscosity @ 100 degrees celcius of approx 7.5/ In the fluids service life it will "shear" down to the mid to low 5's. This is allowed with this fluid. Dexron VI is engineered to start out at lets say 6.0 and only shear a couple of points. It is shear stable.In respect to viscosity allowance they both do the job, they just get there two different ways. It can remain in service for a very long time and maintains shift quality longer as well. It is not yet proven in high output applications as it has not been on the streets very long.
Again, a synthetic atf of the correct spec WILL NOT damage your transmission. Can it cause different shifts that you percieve to be not normal, yes! Sometimes you have to experiment with a few fluids to see what works. And remember, if you only do a pan drain with a different fluid, don't epxect to be able to fully evaluate it as you haven't even replaced half of the total capacity. A cooler line flush will replace 99% of old fluid if done properly(outline under transmission flush on Amsoil.com) and will let you evaluate the new fluid as there will be little to no cross contamination.
All I have heard for the most part in this thread is bad information and stories about other peoples cars. If you know someone that can prove a lube(ATF) related failure using a proper spec synthetic, I really would like to see you post it. People point the finger all day long, but seldom do they have proof. Why? Because we all have a habit of being full of **** from time to time.
I never stated failures related to syn fluid, I said issues. And you can quote viscosity grades all day and it doesnt change the truth in real world applications. Truth of the matter is these cars are aging, lots with 100K+, but I bet your book knowledge doesnt account for that.
I never stated failures related to syn fluid, I said issues. And you can quote viscosity grades all day and it doesnt change the truth in real world applications. Truth of the matter is these cars are aging, lots with 100K+, but I bet your book knowledge doesnt account for that.Oh book knowledge!!!! I have been wrenching on all types of vehicle most of my life. No need to prove it to someone whom is speculating about things he knows nothing about. Waste of time. I do happen to have some knowledge on lubricants. Do I know everything, no.
I am stating physical characteristics of a given fluid. Viscosity along with friction modification has alot to do with ATF. Why dont you look into it before making ignorant statements based upon what others are telling you. 100k is nothing in a well maintained automatic that is in good working order. Most dont maintain them properly and wonder why they have issues. Read my post and you can see that I stated not all ATF's with a like spec will act the same in an auto. Formulas vary from product to product.
Didnt anyone ever teach you that you should never assume anything!??? Guess you didnt get the memo. Any time I see someone making a false comment I am going to call them out. If you don't like it I really could care less. Again, educate yourself on the subject. You are obviously not qualified to speak on it if all you have are insinuations and meager attacks calling me "booksmark". Thanks, I'm also mechanically inclined, have a much nicer car than you and have a better job. Happy now, I'm on your level.
Guess that means you assumed......wait a mintue, I just read....
Next time you respond, do me a favor and bring some data to the table. It's obvious that your are uniformed about lubricants by your poor rebutals. I really could care less about your opinion on the subject, as you have shown you know nothing about it. In the end im arguing with a internet Troglodyte. Until you become informed on the topic at hand, you have no leg to stand on. Keep the insults coming. Really shows class.
Thunderstuck507- As I am intrigued to hear why Yank does not recommend synthetic atf, it really doesn't pertain to this discussion. Yes, some guys are bound to run Yank torque converters, but the original discussion had to do with issues pertaining to the 4L60e trannys in perticular, while running synthetic based atf. Again, there is no data to support claims other than shift quality. No brands were given. We will assume, that they were all DEX III, but don't know. There are too many variables here.
Like it or not, you cannot make unfounded comments that are accompanied with ZERO data. Many of you need to better educate yourselves on this subject. It's embarrassing the amount of misinformation being regurgitated on this site with respect to oil. Laughable really, but at the same time unfortunate because this site does contain alot of very good infomation and resources. Enough with the false information. We are better than that.
I was thinking about this one...
http://www.summitracing.com/parts/SUM-G4969/
But its a little high
http://www.summitracing.com/parts/BMM-70274/
http://www.ws6project.com/user_stor/...oducts_id=2317
Looks to big to mount on the front of the radiator??
