? About Tranny Temps!
Old Feb 1, 2010 | 02:09 PM
  #41
99corvette's Avatar
Sounds like the one I will go with then. I have a 4k stall too. Where did you mount yours?
Old Feb 1, 2010 | 03:26 PM
  #42
Marc 85Z28's Avatar
Originally Posted by 355TurboLT1
Funny how guys like yourself enter into conversations such as these with no qualifications on a topic and use preschool tactics to try and undermine hard data compiled over millions of miles in countless platforms.
Back in the mid 90s, 700R4s were crapping out left and right from people putting Trick Shift in their vehicles. Since those days, synthetic transmission fluid has has a well deserved stigma attached to it, regardless of what you read on BITOG.
The overall design of the 700R4 and the 4L60E are near identical, and they react similarly to a given type of fluid. Maybe the new synthetics are better. Most on here are aware of the fluids history in our transmissions and are not willing to chance an expensive mistake. I am not willing to chance my 4L60E on a synthetic transmission fluid, especially when several converter manufacturers and well respected transmission builders recommend against it's usage. But hey, you have data...
Old Feb 1, 2010 | 06:59 PM
  #43
355TurboLT1's Avatar
Many more builders, CARL ROSSLER being one of them have nothing against running a synthetic. Not all of my DATA is from bitog so you might want to think about your assumptions next time. Amsoil had THE FIRST synthetic atf. There have been several reformulations throughout the years and never any issues. And as far as YANK i have spoken to him and his reasons for not using synthetic is laughable. Again if you guys want to keep living in 1985 (ie denial) then go right on ahead. You have zero data... Just old wives tales and a crappy example of trick shift! Who in the hell even buys a product like trick shift?? Oh yeah, someone that doesn't know **** about lubricants in general. There are alot of you here. Good luck providing evidence and keep spewing false information about subjects you know nothing about. Ignorance is bliss.
Old Feb 1, 2010 | 07:03 PM
  #44
01ssreda4's Avatar
Originally Posted by 99corvette
looks like the one i was thinking about..might actually be the same one
http://www.ws6project.com/user_stor/...oducts_id=2317
Looks to big to mount on the front of the radiator??
Absolutely not, thats where I have mine. Its a super tight fit but you can get it in there. I actually made a small aluminum bracket that holds it out away from the condenser a tad for a little bit more room. The bracket is bent around and attached to the lower radiator support.
Old Feb 1, 2010 | 07:08 PM
  #45
99corvette's Avatar
Alright thanks, i might fab something like that up at work. I just ordered mine
hopefully between that and a deeper pan i can get my tranny temps down under 200
Old Feb 3, 2010 | 05:22 PM
  #46
99corvette's Avatar
alright guys i installed B&M badest bitch today....and its still reaching 250 degrees according to the temp gauge. im starting to think the gauge isnt accurate...
Old Feb 4, 2010 | 08:40 AM
  #47
99corvette's Avatar
Originally Posted by LS1GMCTruck
For a 4L60E in a 4500 pound vehicle, that is used for towing? Anybody have a clue? Thanx
what does this have to do with my thread..start your own. thanks
Old Feb 6, 2010 | 11:52 AM
  #48
99corvette's Avatar
Deep pan with sending unit it in going in today
 Michael S. Palmer
Old Feb 7, 2010 | 09:24 PM
  #49
99corvette's Avatar
Well i dont know if it was the deeper pan of the relocation of the sending unit, but the tranny is staying right about 200 degrees now. Which to me is still to hot for as cold as it is. Gonna put the SLP fan switch in and hope thats enough for the summer time.
Old Feb 8, 2010 | 12:21 AM
  #50
GT Griller's Avatar
I run 2 external coolers and bypassed the radiator...even at the track i dont see 200 degrees...normally about 140 cruising temps.
Old Feb 8, 2010 | 06:23 AM
  #51
99corvette's Avatar
Yeah im thinking about bypassing mine and hooking up the other smaller cooler that i did have.
Old Feb 8, 2010 | 07:15 AM
  #52
redbird555's Avatar
My tranny stays ice cold around 160 normal florida driving with the tranny cooler you have... Have you tried another sending unit/gauge just to make sure they're good?
I'll offer my .02 to the synthetic debate, synthetic imo is the best tranny fluid you can get. It will be in my tranny next oil change providing I dont have a stall for it would void the warranty. To the post up top abt trickshift, I have a bottle of it at home and its a conventional oil, while they do have a synthetic that comes in a silver bottle Ive only seen it for sale on their website. I've seen synthetic atf not once but twice on a 4l30e and a ford AODE completely get rid of slipping clutches when no other atf could. Mind you these trannys were on their way out and even with brand new castrol conventional atf still slipped on shifts normal driving etc, when a full flush and synthetic change was done both tranny shifted flawlessly until the next oil change where conventional was used again and the same thing happened. Normally I wouldnt justify a $110 oil change if I didnt see it work before my own eyes....
Old Feb 8, 2010 | 07:44 AM
  #53
99corvette's Avatar
Is yours going through the radiator? Also what size stall do you have?
Old Feb 8, 2010 | 07:59 AM
  #54
01ssreda4's Avatar
I have ran with and without radiator cooler. IMO, the radiator brings the temp of the tranny up. Bypassing it will drop tranny temps another 10-30 degrees.
Old Feb 8, 2010 | 08:05 AM
  #55
99corvette's Avatar
Alright im going to try this. Surely my cooler is big enough and doesnt need a 2nd one?
Old Feb 8, 2010 | 08:11 AM
  #56
01ssreda4's Avatar
Ironically we are discussing this in another trans thread. About the radiator acting as a heater when the temps are coolant>trans. But when the trans>coolant, it acts as a cooler. How hot is your coolant running? The two liquids are trying to equalize themselves in temps.
Old Feb 8, 2010 | 08:13 AM
  #57
01ssreda4's Avatar
What cooler are you currently running???
Old Feb 8, 2010 | 08:17 AM
  #58
99corvette's Avatar
right thats my thing is, my car had the stock thermostat in it so it runs 200 degrees! So it has to be heating it up. I got B&M badest one they got. almost 30,000 BTU
http://www.summitracing.com/parts/BMM-70274/
Old Feb 8, 2010 | 08:29 AM
  #59
01ssreda4's Avatar
same one Im running.....
Old Feb 8, 2010 | 08:31 AM
  #60
99corvette's Avatar
Arent you running 2 though? I still got my small one that is like 8x11x3/4". I might hook it up too.
