Torque Management?
this is what i heard not what i know but every thing is running great on my car hope this helps
Yes, absolutely it slows you down. If your having TM issues, get tuning! Have it removed. I tried everything to work around it... it's not worth it, bite the bullet and get tuning.
If your not having issues with it and have no other reason to get tuning, then leave it alone.
Josh S.
(just for luck). Driving home I got on it more than half throttle
and on the upshift it actually pulled me forward, it "managed"
so well. Never felt this on the stock converter but the 3000
stall TCI makes it really noticeable - and I never felt it after the
TC install because the Predator tune was in there before & after.
Yechhh.
Josh S.
tenths of a second. Maybe it seems like two seconds.
It is matched to the duration of the shift cycle and
goes away once in the new gear.
If your mixture is way bent ("no tuning"?) and you are
depending on the closing of the loop to get your mixture
back right, this has a lag like you describe.
Bad knock retard also has a long, persistent "tail" that
takes over a second to go away once triggered. Upshift
is where the last traces of KR lurk when you're almost
tuned right. If you're mis-tuned lean, you might have
some big retard values that take time to go away.
Only logging (or at least real-time event viewing) can
tell you what's up with that.
Josh S.
The problem seems to arise at more aggressive launches from a dead stop. Going close to 1/2 trottle, the vehicle "floats" between the first to second shift, and through the rest of the gears, I get alot of "RPM" hunting. When driving the car "normally" I do not experience this, and the car is FAR more responsive. I will have my car dyno tuned in the middle of this month, and I am sure that manipulating the TM settings will solve my problems at more aggressive throttle.
TM WILL DEFINETLY SLOW YOU DOWN.
SteveC
mine could have also been caused because the band was brand new and was sticking to well?
according to my logs and others I've seen. Like -5 degrees spark
advance, but only for two 1/10 second record ticks and then
back up into the +20s.
Now, if your trans is shifting slowwlllyyyy like stock is programmed,
maybe you get a lonnggg TM dwell along with that? But 2 seconds
is a bugger long time for shifting, even stock. Anyway, if you have
something that's hanging up your shift adaptation cycle time you
might be seeing TM all the while.
Log it. If your spark timing is still above 15-20 degrees then you are
not seeing TM. TM squashes it flat.
