Looking for a 4l60e trans pan, with drain plug? advice
I want to go ahead and get an aftermarket pan with a drain plug. Im only at the bolt on level know but next major mod will be a built trans,converter, and cooler. So Id rather just have one I can reuse. So what should I get and need to look for. Idk how a cooler attaches to the trans? Do you have to buy a pan with fittings for it? Im a real NEWBIE when it comes to the transmission stuff.
Thanks guys,
Josh
The cooler attaches to the stock cooler lines, no other modding required.
It sounds like your pan is leaking around the gasket, I have seen some where the bolts loosen up and leak just the way you are describing.
with the factory drain plug. I have one off an '02 Silverado.
These, you can use the truck filter on which puts you deeper in
the juice for no starvation on hard cornering if you're a hair low.
I had a TCI deep pan and ground down the "prongs" to let me
use a truck filter there too. But I was tagging every speed bump
with that one, and figured I needed something that would scrape
less and take more of a beating if it did (truck pan is steel).
im thinking of looking at autozone and oreilley for a bolt in one like that first B&M one.
http://www.google.com/products?hl=en...ed=0CB0QrQQwAg
wondering the same thing, and how much clearance are talking about losing?
