2009 4l70 question
hey guys... im wondering what a 4l70e trailblazer ss transmission will handle.. going into a 65 chevelle and will never be raced, draged or beat on.. its a full time show car..
well the 2009 tbss motor im getting has a 4l70e and also if you search online it says they have teh 4l70.. and i think the only difference is that the 4l70e has a 5 planetary. but i know the 4l70 is on the heavy 4500lb tbss awd and my car is about 3000lbs. i guess well see..
-Beast Sunshell
-Raybestos Z-pak
-Carbon Band
-Alto red HP clutches
-Kolene steels
-Superior 2nd servo, sonnax 4th servo
-Hardened pump ring kit
You should already have 5pinoin front & rear planetary gears. The 4l70 has a few minor changes, input speed sensor in pump, reluctor on input shaft, and boost valve is slightly smaller. So from a performance standpoint the 65/70 are the same
