th400 conversion? Converter suggestions?
Also does anybody have converter suggestions for a 382 all bore motor that will peak fairly high, on a 300 shot, I've heard nitrous likes to pull and doesn't need as big a converter is that true or do I still want a really high stall?
I have the same setup with a 4000 stall Neal Chance. We are going to tighten it up quite a bit as a result of my 300 shot runs. At 200 it engages great. At 300 it starts to power through it a bit. Not sure where I'm going to end up at when it's all said and done. Good thing is I can simply restall mine on the bench rather then sending it back.
Additional pictures can be found here: http://www.derty.org/install/th400
