I need help
Old Feb 26, 2010 | 12:12 PM
LS1rocky's Avatar
Default I need help
ok the problem i am having is kinda weird and intermitent.For some reason on my way home from work my rpms pick up and my speed stays the same(rpms will go to 3-4000 rpms if i let it most times just 2-2500).And it does it at the same spot on my trip home.at the same small hill everytime.When i let off the pedal or cruise most of the time it goes away and will start back up in a bit.Any ideas on WTF is going on?I have floored it when it happens and it feels like it has a hell of a stall.It does not do it on the way to work or cruising around.and it is a small hill that I have to go over a bridge as well(the Coleman in Gloucester)which has 5 times the distance and at least the same grade.Any help on what too check out is appreciated.I am a mechanic but autos are probably my weakest point.oh yea it might help to let everyone know what I am dealing with.its a 00 Z.Thanks again
Last edited by LS1rocky; Feb 26, 2010 at 12:14 PM. Reason: oops I forgot too say what kinda car
Old Feb 28, 2010 | 09:00 PM
LS1rocky's Avatar
no one can help?
Old Mar 4, 2010 | 02:35 PM
LS1rocky's Avatar
not even a sponsor can help?I do not want to lose this trans.
Old Mar 4, 2010 | 03:40 PM
72blownvert's Avatar
Sounds like lock up is cyciling in & out.Check for codes.
Old Mar 6, 2010 | 04:35 PM
LS1rocky's Avatar
ok double checked codes no trans codes at all.Just a cat code and egr code.I think it is something mechanical I just do not know what to look for or try next.Thanks
Old Mar 7, 2010 | 09:50 PM
FLT's Avatar
FLT
With you having codes that effect the drivability of your vehicle, they could also effect the functionality of your transmission. In some cases codes will disable the tcc function and also make a trans only function in certain gears. It might be best for you to do the repairs on the other issues that you are having and go from there. Vince
Old Mar 8, 2010 | 11:03 AM
LS1rocky's Avatar
I will mess with the EGR code I got that code not long before I started having this problem if I remember right.The low cat eff. code has been on for oh 100,000 or so, so I really doubt that is affecting it.Yea the poor girl has high mileage.I am at 181,XXX and running strong.This is my 2nd trans that is probably around 120,XXXon it now,not for sure it was a junkyard special.Thanks for the help.I will let you know what I find out.
