bolt on bellhousing problem?
Old Feb 27, 2010 | 04:40 PM
hevymetalg's Avatar
Default bolt on bellhousing problem?
Okay I dont know if this matters or not but my trans in the car look like a bolt on bellhousing and the trans I got from a 2002 v6 camaro is not. So what do you think? Im not sure? help me! :thinking:
Old Feb 27, 2010 | 06:17 PM
hevymetalg's Avatar
see what I mean?
Old Feb 27, 2010 | 07:18 PM
hevymetalg's Avatar
Originally Posted by Bro Inc
Thats not a 2002 transmission in the picture.
Really? How can I tell for sure? Is their some number on the case
Old Feb 27, 2010 | 07:40 PM
silverz28camaro's Avatar
Yep, looks like an early 90's 4l60e. Maybe the 2002 marker was when they pulled it out of the car.
Old Feb 27, 2010 | 08:41 PM
hevymetalg's Avatar
ok i found this case on ebay will this work if i swap the guts from the 96 trans i have? http://cgi.ebay.com/ebaymotors/4L60E...a#ht_814wt_958
Last edited by hevymetalg; Feb 27, 2010 at 08:41 PM. Reason: forgot link to ebay lol!
Old Feb 27, 2010 | 08:57 PM
Be careful....alot of the parts do interchange but from my knowledge there was a few different pumps and electronics in the valve body that were different.
I THINK 96 up had the same pwm pump and the same solenoids in the valve body.
95 was a odd year and something was different with the pwm. 94 and older were also different.
Do some reasearch. the pump you have may not fit the newer case....??? Most of the other internals will be the same.
did you check craigslist? I have found lots of auto parts there. I just bought a 700r4 np208 to go in my dodge..LOL
Old Feb 28, 2010 | 07:37 AM
hevymetalg's Avatar
Would love to rebuild it but the servo housing cracked in my trans so the case is shot.
Old Feb 28, 2010 | 12:40 PM
hevymetalg's Avatar
I know the pump won't work. Why not empty out your old case and use it?
I think you are going to run into several problems swapping the guts out of a one piece case to a 2 piece.
You'd have better luck with a rebuild kit and your old trans. If you can take old parts out of one and put them in another, you should be able to put a rebuild kit in it instead.
I could buy the case on ebay and rebuild my trans?
 Michael S. Palmer
Old Feb 28, 2010 | 08:52 PM
Got any pics of your old case and where it broke?
Old Mar 1, 2010 | 05:46 PM
hevymetalg's Avatar
yeah its the servo housing lip here in my old post check it out! https://ls1tech.com/forums/automatic...l#post12790893
