no start?
so.. anyway.. my car was taken to the shop and they said they unplugged the battery and rebuilt the tranny and installed the new torque converter and they went and put everything back together and now the car wont start... any Clues on why it wont start now? It acts like it wants to start but just never fires up.. help.. or on the console, but that's a prime candidate.
Of course, that should not even let it crank.
You might check that the impact fuel safety switch
didn't get set off (like if they dropped it hard when
lowering the lift).
the lift).
Start with the basics.
Is the fuel pump coming on? Is there fuel pressure? Did they kink a fuel line while wrestling the trans?
Did they check for spark?
Fuses?
All too often mechanics overlook the obvious. I worked with a master tech who spent 4 hours trying to get a Suburban to start. Had gauges, scanner, meters, shop manual, the works. Couldn't figure it out. A bunch of us went outside to push it in, I slid under and kicked the fuel tank. Fired up first crank
All it turned out to be was a dying fuel pump. Pretty simple problem
