m4 swap connecting reverse lights
Old 04-11-2010, 04:41 PM
gapp94vert's Avatar
Default m4 swap connecting reverse lights
Hey guys I swapped my m6 car to an a4 last sept. The car is a 98 and I used a 98 a4 engine harness for the swap. I mainly swapped for the consistency at the track and everythings been great but my car is due for inspection in a month and I never hooked up the reverse lights or the neutral safety switch. Im mainly concerned about the reverse lights and I have searched and read the stickies but I cant find out where the wires are to connect the reverse lights up. I know on the t56 there was the pigtail on the side of the trans but they arent there anymore since switching to the a4 engine harness. Searching the threads it looks like the brown and light green wire coming off the six pin connector on the a4 shifter are for the reverse lights. Im just stuck on where to connect those to. Anyone have any wiring diagrams for a 98 or any ideas. Thanks, Joe
Old 04-13-2010, 09:56 AM
gapp94vert's Avatar
Anyone?
Old 04-13-2010, 04:40 PM
ss2668's Avatar
Im not sure if the 98 is different or not, but check out this thread.
https://ls1tech.com/forums/automatic...sion-info.html
Post #16 has some good info on what your trying to do.
