Aftermarket trans pan
Old Apr 21, 2010 | 06:29 PM
97ss497's Avatar
Default Aftermarket trans pan
I'm going to be replacing shift solenoids and am going to go ahead and add an aftermarket pan with a drain plug and more fluid capacity. What have you guys used and is there a sponsor here that sells them? Plus is there a sponsor that sells the shift solenoids?
Thanks...
Old Apr 21, 2010 | 08:59 PM
97ss497's Avatar
Come on; no one has installed an aftermarket pan on this site??
I've seen a TCI and B&M offered on a couple different site's; anyone have a preference?
Old Apr 22, 2010 | 05:34 AM
Mr Monaro's Avatar
Smile
Make sure theres enough clearance for the deep pan.
Old Apr 22, 2010 | 10:54 AM
Red99T/A's Avatar
I too am curious as to which deep pan people prefer.
Old Apr 22, 2010 | 07:08 PM
ULTIMATEORANGESS's Avatar
i bought my B&M pan from thunder racing.
Old Apr 22, 2010 | 09:02 PM
97ss497's Avatar
I ordered the TCI 37800 deep pan from Speed Inc.
Old Apr 23, 2010 | 06:43 AM
Hardtop's Avatar
I'm using a truck pan .
Old Apr 23, 2010 | 11:17 AM
BrianC98Z28's Avatar
B&M deep pan here.
Old Apr 23, 2010 | 11:02 PM
sixvi6-camaro's Avatar
Truck pan here as well it came with my FLT trans. It hold and extra quart and doesnt' hang down as low as the cast pans with all the fins. There is no drain on it and I really would not want one. I feel much better dropping the pan as you can see of there are any unexpected pieces laying in the bottom.
Old Apr 24, 2010 | 07:05 AM
FLT's Avatar
FLT
I prefer the TCI pan or a factory delco deep pan. Vince
Old Apr 24, 2010 | 03:51 PM
flak_monkey's Avatar
I was looking at the tci pan for my 95lt1 because it doesn't seem to require a filter extension or a special filter, and has a temp sender bung and drain plug. anybody use378014
Old Apr 24, 2010 | 10:24 PM
PontiacFan's Avatar
Installed the TCI cast pan today & had to modify the inside with a die-grinder & burr to remove material for the OE filter clearance.
I wouldn't do it all over, I'd look the GM truck pan.
Old Apr 24, 2010 | 10:39 PM
Anthony Williams's Avatar
If you ever lower your car a deep pan will be your worst nightmare, just go with a stock depth pan with a plug and a BIGG trans cooler.. and remeber a 700R4 pan is the same as the 4L60E Google it.
Old Apr 24, 2010 | 11:44 PM
sjsingle1's Avatar
any 1 sell a truck pan here......or have the PN for it???
Old Apr 25, 2010 | 12:36 AM
7th Darkness's Avatar
I got me an ebay pan, cheap. The pan still does not go below the headers.
Old Apr 25, 2010 | 01:29 AM
sjsingle1's Avatar
how much deeper is that pan over stock???
Old Apr 25, 2010 | 01:49 AM
z28241's Avatar
I got a Hughes Racing pan extra 2 quarts..
Old Apr 25, 2010 | 01:50 AM
Not sure but it hold 3 or 4 more quarts, I thinks its about a inch or 2 deeper.
Old Apr 25, 2010 | 02:26 AM
sjsingle1's Avatar
did you use the longer filter???
Old Apr 25, 2010 | 03:11 AM
Yes or it would be pointless.
