any 4L60E free mods???
Old Apr 25, 2010 | 05:34 PM
importkiller_SS's Avatar
Default any 4L60E free mods???
I was wondering if there is any info out there about any free mods for a 4L60E? if not free any really cheap mods that help out?
Thanks
Old Apr 26, 2010 | 05:08 AM
Originally Posted by Bro Inc
Maybe a boost valve.
Otherwise no. I wouldn't go with a billet servo, someone might recommend that.
Anything you do requires taking the transmission out which I don't see the point just for a cheap mod.
I wouldn't even recommend a shift kit, except maybe the transgo or sonnax pwm elimination.
i think i got the boost valve from the trans-go kit i bought.
what is the benifit of the pwm elimination? havent heard about it.
Old Apr 26, 2010 | 08:18 AM
cause4panic's Avatar
A quarter turn on the PCS?
Old Apr 26, 2010 | 08:37 AM
PCS? what and where is that located?
Old Apr 26, 2010 | 12:30 PM
You know when you ask for help about a transmission, you should tell people whats been done already.
Don't **** with the force motor screw unless you have reason to. Connect a gauge to it and look at the actual pressure, learn how to read it properly. The transgo boost valve puts line pressure at 236 psi and the white spring that goes inside the actuator valve spring boosts it another 3-6 psi. That makes your max line approx 240 psi.
My max line is 235-240, transgo recommends at least 190 psi to the clutches at wot.
Every transgo kit for a 4L60E whether its the problem solver or performance has the pwm elimination stuff in it.
I had a trans go kit in a previous trans is just wanted to know if that would have been the same valve.
i have a virgin trans sitting around and was just wondering what free mods i could do...
just to make things a little clearer for ya
Old Apr 26, 2010 | 08:03 PM
PBA's Avatar
PBA
If you have the TransGo Shift kit it will have the PWM eliminator valve. The Sonnax setup requires a tool to ream the bore, and does not eliminate the pwm setup. TransGos way is better and requires no machine work. WOT psi. should be in the 220 - 235 range. Adjust the EPC solenoid to get it there if necessary.
Old Apr 27, 2010 | 05:12 AM
cool thanks... i'll have to check out SK
Old Apr 27, 2010 | 07:19 AM
PUNISHER TA's Avatar
Good luck with that.
I think I've given enough free info. And it's not the kind of free info thats going to screw **** up.
Who put the stick up your A$$?
Old Apr 28, 2010 | 08:01 AM
LS1Transam99's Avatar
Every single person who asks a stupid ******* question here and ignores good advice.
If you don't like what I have to say go **** yourself.
wow, hello Mr. Personality
Old Apr 28, 2010 | 08:31 AM
Gordon0652's Avatar
Call FLT or RPM - they are a sponser.
This board gets more immature everyday.
Old Apr 28, 2010 | 12:10 PM
Gordon0652's Avatar
Inc, i know man. not calling anyone out.
I met call FLT or RPM and get something real built. FLT will be building my 7 stage 4L60E for my T/A and maybe for my TBSS if it blows with some mods.
Old Apr 28, 2010 | 01:50 PM
GregWS6&z28's Avatar
Bro went about it all the wrong way but I agree with him. There's no sense in trying to tweak a 4L60E. Just get it built and hope it stays together.
Old Oct 7, 2018 | 05:30 PM
Uforeel's Avatar
Default Pwm delete 2001 blazer
pwm ko
