external precautions to extend tranny life?
Old Jan 8, 2004 | 04:17 PM
02redSS's Avatar
Default external precautions to extend tranny life?
what can i do to make my tranny last a while?
I have a bolt on car with a PT4400...stock computer tuning
It has a stock rebuilt 4L60E in it w/a tranny cooler.
What else would help extend the life of the tranny?
Shift kit? Computer programming? deeper pan?
i know this stuff will help performance, but i'm more concerned about keeping the tranny good for a while. So which would be the best place to spend my money?
Old Jan 8, 2004 | 04:54 PM
emarkay's Avatar
Remember Newton - an object at rest will tend to stay at rest unless attacked by 300+ horses.
Keep fluid cool and clean, and avoid abusive maneuvers, and let the tranny do its magic (no manual selections of gears).
Good luck
Old Jan 8, 2004 | 05:19 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Agreed.
Also, get the deeper pan, set your fans to come on more often, use a trans cooler that keeps the trans temps under 200 at all times. Hell, I have my fans set to run constantly once the car has achived closed loop, just to keep air blowing across the cooler at all times....
Old Jan 14, 2004 | 11:41 AM
emarkay's Avatar
Interesting, but are you worried about the current draw, and the MTBF of the fan motors?
Seriously, at any speed above 25MPH, you are flowing enough air thru, and at higher speeds YOU MAY BE IMPEDING the air - sure they will prob freewheel when off at 70MPH, but do they when ON???
Old Jan 14, 2004 | 06:21 PM
RPM WS6's Avatar
No, why would I be? I've been using this 'trick' for years on many performance cars, never had an issue. Stock, the fans are meant to run whenever the coolant is at a certain temp, until it reaches (drops) to a certain temp. So, say you live in TX and it's 100* out and you're driving in traffic with the A/C on. Even stock, they will be running constantly. Actually, a few cars I've owned have been factory set to run the fans constantly when the A/C is on, period.
I disagree. I don't see how the fans could signifigantly impede airflow at speed anymore when running than they do when not running.
If this was the case, then I would observe higher coolant temps at 70mph than at 20mph, and I don't. My highest temps are still seen when sitting idling.
Also, I don't recall ever having any issues with my old belt/crank driven fan cars. My old '71 Cutlass used to see 110+ mph blasts quite often, along with lots of 70mph cruising.
