vig 3600 to small for my setup?
Old May 1, 2010 | 09:41 PM
predator200289's Avatar
Default vig 3600 to small for my setup?
Im looking at doing a swap from my m6 to a a4, i found a good deal on a vig 3600 stall and im wondering if it's to small?? my setup is in my sig my car is making 524rwhp 563rwtq. plan on getting off the safe tune though car should make around 550rwhp 600rwtq
Old May 2, 2010 | 02:58 PM
TXZ28LS1's Avatar
the vig 3600 will be fine.
Old May 2, 2010 | 04:09 PM
PGUFF's Avatar
if those numbers are with nitrous, I don't think you would want any bigger
Old May 2, 2010 | 06:02 PM
ok so you think a 3600 would be fine. I know on the dyno the cam really starts coming on about 3900-4000. Do you think id be happier with a 4000?
Old May 2, 2010 | 06:11 PM
johnster's Avatar
ya i would go bigger
Old May 2, 2010 | 06:17 PM
1989GTA's Avatar
Question? Is it the Vigilante convertor that is typically rated about 400 rpm's low? The Yanks are usually pretty close. If that is true than a 3600 Vig would be about the same as a 4000 Yank. If not disregard this post.
Old May 6, 2010 | 03:54 PM
1qwkz's Avatar
i would not do a 4000 itll be too loose sprayin
Old May 9, 2010 | 05:46 PM
99ccz28's Avatar
The Vig 3600 wil stall around 4000. I have that converter in my car right now.
Old May 9, 2010 | 11:18 PM
robsquikz28's Avatar
Old May 11, 2010 | 11:45 PM
SOMbitch's Avatar
I bet it stalls higher than 4k when he hits the button....
