Need help th400 install in a 97 LT1 firebird
I have the trans, cooler and lines that I can make up for the car.
Can I reuse my stock crossmember a4 for the conversion?
ITs a short tail shaft trans, Can I reuse my stock driveshaft?
What converter will I need to get a sbc standard or does it have to be lt1 specific?
What shifters fit in the stock console, pics and part numbers would be great?
thanks and hope this helps and you can help me
you need a new driveshaft
converter should be a standard sbc
I'm going with either a cheetah or stealth ratchet shift, not using my old console though.
no.... th400 uses a different yoke.
https://ls1tech.com/forums/conversio...available.html
You could get either your 400 yoke in a bolt on style or fixed to driveshaft style if you have driveshaft made.
