Need help on a stall install.
Old May 12, 2010 | 12:43 AM
JonCR96Z's Avatar
Or if the converter is too far away from the flywheel and you don't add any shims, it could pull it back out of the pump. Did you check the converter to flywheel spacing?
You can unhook a trans cooler line and see if it pumps fluid out. If not then you've got no pump.
Old May 12, 2010 | 08:17 AM
SSHAWK's Avatar
Is there any way to test the pump once the tranny is down???
Old May 12, 2010 | 08:39 AM
MIKEY'S 2002 TA's Avatar
Default trans pump
do what joncr96 said. pull a trans line off at the trans cooler. if the pump is working it will shoot trans fluid out. its most likely the pump. i had the same thing happen to mine and a mechanic put my converter in.
Old May 12, 2010 | 09:30 AM
twitchtwice's Avatar
yeah i guess i could explain better. once you get everything squared away and start to put the converter back on. what you do it spin it while pushing it in. it should fall in three times. then once you mate the transmission up to the block there should be about a 1/8 space between the flywheel the the converter (make sure the converter is pushed all the way into the transmission when you measure)
Old May 12, 2010 | 09:45 AM
SSHAWK's Avatar
Thank you for the info on the spacing.
Old May 12, 2010 | 10:11 AM
KirkEvil's Avatar
I followed this for my TC install, skip to step F for some measurements before bolting up the Trans
http://modernmusclecars.net/forums/a...p?do=tcinstall
Old May 12, 2010 | 10:24 AM
Hotroddin's Avatar
^ after reading that, i think i understand how the pump gets smashed, is it because if there's not enough room between the flywheel and TC, when you bolt up the trans the flywheel smashe's the converter into the trans, in turn smashing the pump?
Old May 12, 2010 | 10:34 AM
SSHAWK's Avatar
Awsome guide
Thank you!!!
Old May 12, 2010 | 10:40 AM
no i believe its because the stall isnt keyed all the way into the pump which causes it to tear the pump up as soon as it spins.
Old May 12, 2010 | 10:41 AM
Hotroddin's Avatar
oh, well damn lol. Im a little bit nervous to install my stall in the next week or two.
Old May 12, 2010 | 10:42 AM
SSHAWK's Avatar
Originally Posted by waterbug1999
sounds like you smashed the pump by not lining the verter to it right... The car wont do anything
And thats what happend... Tabs are broken on the Verter
Can the tabs be fixed or do you have to buy a new pump?
Old May 12, 2010 | 10:46 AM
  #32
dont be worried. im a stupid 19 year old that has never done this stuff before and i did it successfully. just follow what i said earlier.
put the converter onto the transmission and slowly turn while pushing in on it and it will key in 3 different times. if you do this you will be fine, plus you check the spacing once the transmission it bolted to the block, if the spacing isnt correct you either didnt put the converter on right or might need spacers to make up for the gap.
sorry to hear that. you will need to buy a new pump.
Old May 12, 2010 | 10:56 AM
  #33
SSHAWK's Avatar
I wonder what the cost will be for a new pump?
Old Jul 18, 2010 | 06:56 PM
  #34
Sykokilla's Avatar
My mechanic didn't read the directions on seating the verter. Same is happening to me. I'm about to go out and do the ol' pump test and see if anything comes out of the tranny line to the cooler.
