something broke???
Old Mar 25, 2010 | 11:10 PM
caviness's Avatar
Default something broke???
got ? for you all driving down road at 60 car made a pop sound then no gears its got park but thats all have any ideas,wasent even getting on it the wife was driving.the trans century stg 2 4l60 with circle d converter about 3600 to 3800 stall if that helps.
Old Mar 25, 2010 | 11:52 PM
the_merv's Avatar
Veteran: Air Force
If you shut the car off and turn it back on will it move when you shift it into 1 or 2?
Old Mar 25, 2010 | 11:59 PM
caviness's Avatar
ill check that tommorow i havent even started the car since i got it off the rollback,but it did leak sum fluid in the front around the bellhousing area.
Old Mar 26, 2010 | 09:00 PM
OUTLAWZ RACING's Avatar
Sounds like the front seal or pump took a dump.
Old Mar 26, 2010 | 09:12 PM
caviness's Avatar
also it has about 5000 miles on it,on the street only no track or stickey tires yet.i think it might be the pump to,the front seal wouldnt keep it from moving.
Old Mar 27, 2010 | 04:37 PM
caviness's Avatar
bump for any more help.
Old Mar 27, 2010 | 05:00 PM
the_merv's Avatar
Veteran: Air Force
Can't really give ya any more help until you see if it moves in 1..
Old Mar 27, 2010 | 05:06 PM
caviness's Avatar
going out right now to check.
Old Mar 27, 2010 | 05:08 PM
caviness's Avatar
started it up nothing in any gears just like netural only hase park
Old Mar 27, 2010 | 05:15 PM
the_merv's Avatar
Veteran: Air Force
Yea that's the Pump or the Convertor..
Old Mar 27, 2010 | 05:27 PM
caviness's Avatar
just my luck....
Old Mar 27, 2010 | 05:29 PM
the_merv's Avatar
Veteran: Air Force
That's why I went to a T56..they aren't as bitchy when parts fail..you can still move most of the time..
Old Mar 27, 2010 | 07:19 PM
MIKEY'S 2002 TA's Avatar
Default pump
hi, same thing just happened to my car. i had no gears at all. repaced the trans pump and now it has all the gears. good luck
Old Mar 29, 2010 | 06:07 PM
caviness's Avatar
my car was factory 6sp,just changed to a4, 3 months ago,like the auto way better.
Old Mar 30, 2010 | 12:28 AM
the_merv's Avatar
Veteran: Air Force
Till now..
Old Mar 30, 2010 | 04:42 AM
346ci's Avatar
Sounds like you're going to be pulling the trans. If you have a gauge you could always check your line pressures, good luck
Old Jul 18, 2010 | 07:00 PM
Sykokilla's Avatar
Same happened to me man, did you figure out what caused it?
im going out now to see if its the pump. . . . . taking the line off to see if it pushes and fluid out the tranny. if it doesn't. . . . then i know what happened.
here's my thread. https://ls1tech.com/forums/automatic...l#post13553995
