Wont Shift!?!?!?
Old May 17, 2010 | 09:00 AM
gnictry's Avatar
Default Wont Shift!?!?!?
Built meaning "the beast" performance sunshell,raybestos clutches,corvette servo,steel pump rings,Teflon bushing and stronger 2-4 band. Put in in 2008 with 104k on car...now has 128k.
Mods:
built trans-as stated above
3200 stall
228 cam/push rods/double springs
ls7 lifters
trans cooler
373 gears
ls6 intake
ported/painted tb
no egr/air
slp lid/maf
obx longtubes/y
hooker catback
auburn
adj lca/reloc. brkts
sfc
strut bar
tune by frost
ran 12.4-12.300
I have gotten solenoid 2 stuck off code multiple times, have replaced it once and was told it common for stalled cars.
Recently got code again...has not occured in a while. Erased code and went on ...
few easy burn outs no track runs since code...
Was fine on way out last night and way home it acted like it not want to shift...would just rev...
shifted out of first but not sure what gear it shifted to...i was limping it home... didnt want to mess it up more...
Couldnt keep a steady speed above 30 with out revving...
Any ideas if solenoids or stall or what else could it be???
Old May 17, 2010 | 10:13 AM
gnictry's Avatar
anyone...15 views no suggestions...nothing???
Old May 17, 2010 | 11:54 AM
ybaslo1's Avatar
Dunno, what codes do you have now?
Old May 17, 2010 | 01:16 PM
gnictry's Avatar
no codes now
Old May 17, 2010 | 01:38 PM
ybaslo1's Avatar
You have no codes and your transmission is slipping? Interesting. I have no idea man.
Old May 17, 2010 | 01:59 PM
gnictry's Avatar
exactly my thoughts...hope just solenoids since code was thrown earlier but in like it not even engages into next gear...just rev jerk rev jerk...so could be clutches or stall or just need another rebuild but is only has 24k on rebuilt from 02 ws6 that had 60kmax on it...
Old May 20, 2010 | 08:34 AM
gnictry's Avatar
1 2 and rev is fine..going from 2 to 3 revs...slips...let off gas and jerks like skips to 4th but no stall lock up...test solenoids tonight...
Old May 20, 2010 | 09:27 AM
performabuilt's Avatar
LS1Tech Sponsor
1st the code you were getting for the solenoid was not the solenoid its a common false code created by the high stall converter and should have been tuned out in tuning to solve it.
However what your experincing now sounds like a 3-4 clutch failure. Its not a solenoid issue.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 20, 2010 | 11:00 AM
gnictry's Avatar
thats what i am thinking..i got a scanner to test solenoid operation just to mark off list...would it need a full rebuilt if its 3-4 clutches? What would you recommend for parts?
Old May 21, 2010 | 02:31 PM
gnictry's Avatar
okay no codes....had scanner on and drove...shift 1, 2, 3..third revs and i have to let off, jerks into 4th...4 pulls but feels little weak...stall not locking up either..still think its clutches?
What do 3 and fourth have in common?
What causes the stall to lock up (what does the ecu command that actually locks it)?
