revmax converters
One should be like you said where everyones on yanks or vig's
and how you should never ever buy anything other then name brand expensive items and then the other one should be actual acounts of people using them with massive success or disasterous failure and should be STRICTLY enforced by the MODs to keep it that way.
Now i for one still am running stock still so im completely unbiased and ignorant at the same time. I havnt had ANY of the stated converters above in my car NOR have i ever driven one so let the games begin
https://ls1tech.com/forums/generatio...k-results.html
People trashing the RevMax converters treat it like some piece of Chinese junk (as I trash China) and make it sound like their quality is way below the stock converters.
So, how do the RevMax converters stack up to the stock converters??? (The ones that seem to do fine when people want more HP and traction, but aren't ready to fork over the cash for a new trans and/or converter)
BTW, how does a converter make an engine blow?
eventually wears the crank.
its a 245mm converter.
Extreme Street/Strip 9.5″ 245MM Torque Converter
Customized Stall Speed, available from 2500-5000
Performance Rated up to 850HP *Lockup Units*
Custom Built To Your Vehicles Excat Specifications
Anti Balloon Plates
Mechanical Diode Sprage Assembly Upgrade Available
Steel Stator Assembly Upgrade Available
4130 Chrome Moly Flanged Impeller Hub
SOLID ONE PIECE CNC BILLET FRONT COVER ASSEMBLY
Custom Billet Dampner Piston Assembly
Extra Wide High Performance Lockup Clutch Friction
Available with Triple Disc Lockup Clutch
4340 Hardened Turbine Hub and Splines
Completely Tig Welded Reinforced Impeller
Tig Welded Reinforced Turbine
Torrington High Performance Stator Bearings
Torrington High Performance Turbine Bearings
High Performance Max STR Torque Stator Sprag Assembly
Computerized Robotic Sealing Welds
TCRS Computerized High Speed Balancing to less than 5 grams
Nearly 12lbs light than a factory 12″ Converter
Runout Tolerances of less than .005
