Ultrabell Works!
Old Jan 14, 2004 | 08:17 AM
PaiN's Avatar
Default Ultrabell Works!
Some of you may remember when I did the huge wheelstand over a year ago, it shattered my bellhousing on my T350. I took some good advice from GeorgeC, and picked up an ULTRABELL SFI bellhousing, and had it installed on my T350 when I had it torn apart and checked out. I ended up selling that tranny, but I heard yesterday that the new owner has had one companies aftermarket flexplate come apart ( twice ). The first time apparently they caught it early. New flexplate was installed, and sometime later the outer ring sperated on it, and the piece basically shrapneled in the bell housing, and the Ultrabell did the trick, and contained it all.
Definately a worthwhile mod in my book, especially if your running any kind of power.
Larry
Old Jan 14, 2004 | 09:47 AM
FEAR THE LS1's Avatar
I agree..
I bought my TH400 from JW with thier Ultrabell upgrade, that sucker is thick as hell eh?
It is heavier but it gives a little extra piece of mind. Better safe than.. you know...
Lee
Old Jan 16, 2004 | 01:28 PM
JoSeY's Avatar
Originally Posted by FEAR THE LS1
I agree..
Lee
than footless?? yes I agree...now if only they could get a bellhousing for the 4l60's SFI approved or the T56's...
Old Jan 17, 2004 | 07:04 AM
Fast SS on TNT's Avatar
I have the JW Ultra Bell on my TH400. I have heard numerous horror stories about "budget" racers that have lost thier feet, or bleed to death on the way to the hospital from the flexplate exploding.
When your talking life or limb, there is no budget to consider.
Old Jan 19, 2004 | 11:56 AM
kp's Avatar
kp
just curious in who's flexplate came apart, if you dont want to post it you can PM me but I want to make sure its not one I am going to buy
Old Jan 19, 2004 | 12:56 PM
The Juggernaut's Avatar
I bought a TCI sfi flexplate.Please let me know if that is the one that came apart.
Old Jan 19, 2004 | 01:44 PM
BIGBOS's Avatar
I heard the TCI's were supposed to be pretty good, I was considering getting one.......
How much does it cost for this ultrabell upgrade?
Old Jan 19, 2004 | 02:12 PM
kp's Avatar
kp
The ultrabell costs 200.00, you just cut off the stock bellhousing and the ultrabell bolts to the front pump. Its a very nice piece..
Old Jan 19, 2004 | 03:13 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I hear that you need to install the Ultrabell on a jig Kevin?
Old Jan 19, 2004 | 04:25 PM
PaiN's Avatar
Well I'm not gonna post it in here, because I didn't own the flex plates in question. The point of the post is just to let you guys know that there are some good safety options out there. I can tell you from experience that the bellhousing on the t350 I had was thin as hell. The Ultrabell is a very sweet unit.
My tranny guy, cut off the bellhousing on my t350, and mounted it to the fron pump. Didn't look like a monster job. As far as I know it didn't require a jig of any kind. I could try to dig up some photos.
Old Jan 19, 2004 | 04:29 PM
kp's Avatar
kp
no jig needed as far as I know, its located by the front pump. I never did one on a TH350 but I did a couple on powerglides and all you need is a cutoff wheel or sawzall. I never even got any instructions with them, just a bag of longer pump bolts and the bell housing..
Old Jan 19, 2004 | 04:34 PM
PaiN's Avatar
Larry
Old Jan 19, 2004 | 05:12 PM
BIGBOS's Avatar
That looks like a nice piece, is it pretty heavy?
Old Jan 20, 2004 | 11:42 AM
mongse's Avatar
I ruin the end of films...
I had my factory housing hacked off at the tranny shop ahead of time. The UB bolts to the front pump, no problemo. Everything about it is thicker than stock. The case, flange, everything. It's aluminum too, so it's not that heavy. It was a no brainer for me since the pirate peg-leg look just isn't my style.
Arrrghhh!!
Old Jan 21, 2004 | 10:38 AM
Black Sunshine/ 00SS's Avatar
One important thing to check on the LSX when using this housing.. The bolts on the the back cover of the engine keep the housing from mating up with the block when you bolt the 2 together.
BEFORE bolting up to your tranny, bolt it to the engine first, with all bolts. Tighten bolts, then look from under the car, between the engine & housing, while shinning a light from the top of the housing. You will see the bolts & you will see a gap.
Now take the housing off. You will see impressions on the alum housing from the bolts. I think 3 of them. Get out your air grinder & recess those back.
I learned this the hard way, after I broke the flywheel. Lucky I still had a leak to deal with & had to take the tranny out. That's when I noticed the cracked flywheel.
I have some picks I could post on my website, if anyone is interested. Just a heads up. I wasted alot of time dicking with this... You dont have to.
Old Jan 21, 2004 | 12:18 PM
DERTY's Avatar
The Bull
Yup, Harolds right. If you are not running a mid plate you MUST do this modification to the ultrabell or you will cause hell on your tranny.
The four top bolts along the rear cover protrude beyond the surface of the cover shown here.
You need to cut notches in the ultrabell to clear over the top of those, shown here:
If you don't do that you will misalign the bellhousing to the block. That will cause the converter to align with the shaft of the tranny and torque on the flexplate unevenly under load.
The ultrabell rocks for sure. Highly recommended if you enjoy walking and would like to remain that way.
Old Jan 28, 2004 | 03:57 PM
GrannySShifting's Avatar
Well I defintely want to knwo what companies flexplate came apart!
Old Jan 28, 2004 | 04:05 PM
BIGBOS's Avatar
Yea, I'm interested in the flexplate mishap info too..........
How much of a weight gain are we seeing with this ultrabell......
Old Jan 29, 2004 | 10:16 PM
DOC OTIS's Avatar
Hmmm I just bolted my tranny up last week w/ultrabell and it seemed to mate up against the block just fine? Guess I am going to have to take a closer look. If there is no gap between the block and bell housing I am assuming it is fine. This is the first I have heard of this problem. Is this happening on all of these set-ups are just an isolated problem? thanks
Old Jan 29, 2004 | 10:19 PM
DOC OTIS's Avatar
This is probally **** but by grinding on the bellhousing would that tamper with SFI certification? Not that a tech would ever see it just curious?
