flexplate ?
Old Jun 23, 2010 | 05:58 PM
mr_biscuitz's Avatar
Default flexplate ?
Do I have to have a ls specific flexplate or can I buy any sfi approved flexplate? Does it matter if its a flat or curved one? For a th400
Old Jun 24, 2010 | 12:06 PM
FTICONVERTERS's Avatar
LS1Tech Sponsor
we have the sfi apporved billet flexplate that has all three boltcircles for the converter. We also have the pilot extender for use with a stock pilot th400 converter. give us a call at 1-866-726-8358
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Jun 24, 2010 | 01:04 PM
odarabla's Avatar
It really depends on what year car you have. If you have a 98-00 then that flywheel has both bolt holes. The 01-02 models have the new flywheel that didn't retain both bolt holes. I believe on the older flywheels all you have to do is drill out the holes that are already stamped. I just had this issue with my car. It's a 2002 Z28, I was swapping in a th350 into. I had to end up buying a TCI flywheel for my car to make the converter bolt up. Good luck man.
Old Jun 27, 2010 | 07:26 PM
so any ls flexplate will work with the th400?
Old Jun 27, 2010 | 09:56 PM
dnkynrbk's Avatar
Hey DORK I live right by you. You could have called me. lol
Old Jun 27, 2010 | 09:59 PM
dnkynrbk's Avatar
Get the FTI on or a TCI. Do not use a stock flexplate
Old Jun 27, 2010 | 11:51 PM
DSkyles's Avatar
^Truth. I had a friend with a stock 01 t/a and his broke under part throttle
Old Jun 28, 2010 | 06:13 PM
Ive found some SFI approved ls flexplates from 89.00-140.00 for the cheaper brands and then you have the big baller names for 200-250. I dont want it to blow up but to me if there both SFI approved then I dont see a difference besides somebody is marking theres up more. Im a cheap *** Anyways with an older style converter do I have to have the dual pattern or can I just massage the stock holes? Btw how is the Dorks car coming?
Old Jun 28, 2010 | 06:43 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I've also got the TCI flexplate, I had PTC build the converter with for a LS swap so I didn't have to run the pilot extension
