How High Are You Shifting Your 4L60E
Old Jul 3, 2010 | 12:56 PM
1989GTA's Avatar
Default How High Are You Shifting Your 4L60E
Just wondering at what rpm you are shifting your 4L60E? I have a built 4L60E using one of Dana's(Pro Built) kits. Right now I'm shifting at 6400rpm but with my new motor I expect to be shifting in the 6800-7000rpm range. Just wondering if anyone else is shifting their 4L60E that high of an rpm?
Old Jul 3, 2010 | 02:32 PM
02 BLK WS6's Avatar
6800 here, no issues.
One simple mod that helps maintain pressure at higher rpm's is a hardened pump slide spring.
Old Jul 3, 2010 | 05:23 PM
1989GTA's Avatar
Thanks, hopefully that was in the kit.
Old Jul 3, 2010 | 11:31 PM
Minshall's Avatar
When I had mine in last year i was shifting it at 7200.
Old Jul 4, 2010 | 12:01 AM
01ssreda4's Avatar
Old Jul 4, 2010 | 08:42 AM
69LT1Bird's Avatar
6800 here
Old Jul 4, 2010 | 11:34 AM
1989GTA's Avatar
Thanks guys. Good to hear.
Old Jul 5, 2010 | 03:05 PM
chrs1313's Avatar
7300 on stock trans...
Old Jul 5, 2010 | 03:12 PM
FLT's Avatar
FLT
AAHHH
Old Jul 5, 2010 | 05:49 PM
chrs1313's Avatar
Originally Posted by Vince @ FLT
AAHHH
haha I had to...you will be getting a peak under her skirt soon...probably drop it off this Friday...
Old Jul 5, 2010 | 06:03 PM
PBA's Avatar
PBA
If you added the restrictor plug to the input drum that replaces the checkball capsule, it will be good to 7,800 rpm with any problems. If not, then "sometimes" it can present a problem at high rpm.
Old Jul 7, 2010 | 10:32 PM
99T/AMAN's Avatar
6,400 right now but going up to about 6,600-6,700
Old Jul 7, 2010 | 11:45 PM
1989GTA's Avatar
"If you added the restrictor plug to the input drum that replaces the checkball capsule, it will be good to 7,800 rpm with any problems."
I don't recall what we did exactly. We used the kit provided by Dana of Pro Built and followed his recipe for the transmission build. I told him what I wanted out of the transmission and he provided the upgraded rebuild parts and the instructions.
