Tried d instead of od at the track
As usual a bunch of people use the generic 'it'll burn your transmission up' without getting into specifics.
Anyone have anything specific, because honestly I know this is bullshit.
This is ONE time I made a video of me doing it, http://www.youtube.com/watch?v=Eb4DUGWhAqM
I've done it several times since, in fact I lost it once and did a 360 going to WOT at 90 mph. It went sideways at 130, it did a 180 at some point and went backwards around 80 to 60mph then did another 180 and kept going after I restarted it.
I later got my converter restalled and tore the trans down for inspection since it was out, and found nothing wrong.
I built it. It has a stock width BW hi energy band, stock servo, plugged 4th accumulator feed. It's got the 3-2 valve blocked to shorten the 3rd circuit. And a few other things.
D will apply the over run clutches which helps the forward sprag hold, thats it. The low roller holds in 1st in 1, 2, D, OD. Whenever it's in 1st no matter the gear selected.
Some builders are using the Sonnax valve that applies the over run clutches in OD. Other than that, how many 3-4 upshifts does it take, and why hasn't my build failed.....
WOT in 4th is not good it creates too much heat in the trans due to the converter rememebr the converetr is the #1 heat source in the trans with the pump being next. also due to the load that is placed on the trans in 4th on a mtor with modearte torqe it is possible for it to start driving through the band. you may not have any problems doing it but down the road you will. unless the trans is built for this IE wide band and servos and band clearnce you take the chance of smoking the band on a stock weight car with moderate torque. its not to bad on it when it shifts at 130mph because you have enough speed howevr shifting at lower mph is where the prob is however you will still create too much heat in the higher MPH also
I just leave mine in OD, IIRC. As I understand it, leaving it in D just locks out 4th (OD), but like everyone else said, you don't get up to a speed where it would need to shift into 4th anyway, plus I don't think it could even if it wanted to, since I don't think it'll shift into 4th at WOT.
I rememeber with my '88 GTA, after I pushed the pedal down so far it would automaticvally kick down into 3rd, fastest I oculd get that car 115-ish or so, then it would shift out of OD and the motor would redline.
Thats because the stock 700R4 tv sleeve wouldn't let it. Just about every trans company makes a sleeve to allow WOT in 4th on those.
Side note: The stock 4th apply servo is almost identical in apply area as the Corveete servo. So if you block or limit the 4th accumulator and increase the apply feed hole size in the separator plate, you should have no problems with a 3-4 WOT shift, if you decide on making one.
There is a "pee" hole that sprays oil on the planets, it is better to block the accumulator from traveling than to kill the oil going to it.
