Possible trans failure
Old Aug 1, 2010 | 08:41 PM
01BlackCamaroSS's Avatar
Default Possible trans failure
I have a performabuilt level 2 4l60e. it has been in my car since the summer of 2007. The other night on my way home i decided i was going to get on my car from a red light. i reved it up a lil bit and went to take of when the light turned green. The car went right to the rev limiter and did nothing. I put it into 1 and went thro the gears and got it into od. It then started acting really werid. at the time before i tried to launch at a light the trans temp was at 170 when i made it back home which was maybe 10 min away the temp was at 190. i pulled the trans dip stick out and it had metal shavings on the end. I did this 3 more times with the same result. Now im trying to figure out if the trans shitted out of it was the converter failing. Any help would be awesome thanks
Old Aug 1, 2010 | 09:28 PM
jakeshoe's Avatar
Sounds like a broken forward sprag.
No matter who builds it that is always a weak spot in the 4L60E trans.
It could cause metal shavings.
Pull it out and try again.
Old Aug 1, 2010 | 09:51 PM
am i gna have to rebuild the whole trans?. im not knocking performabuilt at all i am really pleased w the overall quality of the tranit percormed really well over the last 3 years
Old Aug 1, 2010 | 10:07 PM
jakeshoe's Avatar
With metal shavings in the pan, there is likely metal in every crevice in the trans. So I would suggest a complete teardown, thorough cleaning of all parts, replacement of all friction elements (metal can become imbedded in the friction material), etc.
Basically a full rebuild.
It's not a hit on Performabuilt or any other trans builder. It's a weak design and to my knowledge ( I don't specialize in 4L60Es so I don't stay as up to date as some) there is no improved part for this other than the dual cage sprag everyone uses. It's a load bearing component that simply has a limit and shock loading kills them.
I'm amazed they hold up as well as they do.
Old Aug 1, 2010 | 10:15 PM
thats what i figured i know a lil about auto trans i knw they r super clean and dont like alot of heat. anybody got any ideas on a price range to get this bad boy rebuilf i need it strong and able to hold up for my nitrous loll
Old Aug 1, 2010 | 10:58 PM
my other idea what seeing what i would needto do to put a th350 or400 in my camaro and what it would be like as a weekend/drag car
Old Aug 3, 2010 | 11:51 AM
performabuilt's Avatar
LS1Tech Sponsor
We offer a restore on the units its 950 and including shipping both ways all parts and labor with a brand new warranty.It could be a trans or converter failoure but in either case you must have the trans gone through.
Thanks
Frank
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 3, 2010 | 12:20 PM
how much would it be for a new converter
Old Aug 3, 2010 | 01:29 PM
with the rebuild
Old Aug 3, 2010 | 03:29 PM
marland speed inc's Avatar
the sprag sound like it needs to be replaced
Old Aug 4, 2010 | 01:10 AM
LS1Tech Sponsor
A new converter billet from us would be 845 more with the build that would also get you a two year warranty on both
__________________
Call 888-744-6542
