Paddle Shifter on Steering Wheel
Old Jan 22, 2004 | 01:01 PM
InvisibleSun's Avatar
Default Paddle Shifter on Steering Wheel
Would it be possible to fabricate something like they use in Nascar (and in a lot of other cars) so you can shift gears from your steering wheel. Downshift with your left hand and upshift with your right. This would be used with a TH400 w/ a GVOD unit. I saw some post mentioning you could have buttons on the wheel to shift with (with the help of programming from a TCI T-Com). Any ideas?
Old Jan 22, 2004 | 03:00 PM
JS's Avatar
JS
I had it in my 97 383 Hawk..
TCI T-Com lets u run a paddle type shift device,We hooked it into my steering wheel radio controls but I dont think u can do this with a 400 being that its not an elec. controlled trans....
JS
Previous car
"Hawk From Hell 383 DFI-Duel Stage N20"
HP Pontiac Article April 98
10.62@128
Old Jan 22, 2004 | 03:19 PM
So you basically just hit the radio control buttons to shift? That's pretty darn cool...
Old Jan 22, 2004 | 03:35 PM
JS's Avatar
JS
Yeppers,Lost radio controls though...
It was kewl but I eventully took it back out and hooked the radio back up..
Old Jan 26, 2004 | 09:39 PM
Cheatin' Chad's Avatar
No problem. Use and air shifter set up and put the buttons on the wheel.When you run out of C02 shift as you normally would.
Old May 28, 2005 | 10:36 AM
Frizzle Fry's Avatar
Default Manumatics for all
I know this is an old string, but I don't like to start new strings on old subjects... Just saw this in Popular Hot Rodding. The Twist Machine steering wheel mounted paddle shifting unit http://www.twistmachine.com/. Looks BADA$$! Works with electronically controlled trannys. It would be on one of the new 5 or 6sp autos. Too bad I already have an M6... Maybe I'll have to swap
Old May 28, 2005 | 03:35 PM
evilbadz's Avatar
The 4L60E isn't electronic is it?
I guess i could make it electronic by putting a stepper motor control on it, but it would take me a few days just to make it shift by itself. Probably not worth the time.
Old May 28, 2005 | 03:58 PM
John_D.'s Avatar
Yes, the E is for Electronic...
There's a big bundle of wires that drop in on the passenger side. Some of them control the solenoids.
Old May 28, 2005 | 05:32 PM
evilbadz's Avatar
Have a wiring diagram? If so I'm gonna have paddle shifting in a few days. Or I guess I could just get out my multimeter...
And 98 A4s DO have the 4l60e right?
Old May 28, 2005 | 06:11 PM
obZidian's Avatar
yes, they all come with an 4l60e or a 4l65e. Basically an electronic 700r-4
Old May 29, 2005 | 05:13 PM
John_D.'s Avatar
I'm looking through my '98 Helms right now. Here's what I've got so far. (the on/off pairs are for the 1-2 shift solenoid, and the 2-3 shift solenoid)
1st: on, on
2nd: off, on
3rd: off, off
4th: on, off
Old May 29, 2005 | 05:27 PM
John_D.'s Avatar
Looks like the solenoids share a 12v power feed, a pink wire at E at the tranny. They are switched by a ground being made by the pcm. PCM connectors: C1 blue, C2 clear.
1-2 shift solenoid is A at the tranny, pin 4 on C1 at the pcm. It's light green.
2-3 shift solenoid is B at the tranny, pin 44 on C1 at the pcm. It's Yellow/Black.
A couple of other ones you might need to know:
3-2 shift solenoid is S at the tranny, pin 48 on C2 at the pcm. It's white. Might have to disable this one, I'm not sure if it's needed or not if you manipulate the other 2 solenoids.
Torque converter clutch solenoid is T at the tranny, pin 79 on C2 at the pcm. It's tan/black.
Not sure what you'd need to do about line pressures, shift speed, etc...
