How to wire up clutch pedal for auto swap?
Old 08-15-2010, 04:39 PM
mr_biscuitz's Avatar
Default How to wire up clutch pedal for auto swap?
How do I wire the clutch pedal up so that the computer always thinks it to the floor to start the car? Done a search but couldnt really find 100% answers.
Old 08-15-2010, 04:56 PM
subhumanzz's Avatar
connect the two wires for the neutral safety switch, tape the switch closed, tuck the clutch pedal under the carpet which will in turn depress the switch.
Old 08-15-2010, 05:36 PM
Gingervitis Addict
slow67's Avatar
I omit the clutch switch all together and extend the wires to the NSS.
Old 08-15-2010, 05:57 PM
ss1129's Avatar
^^^ What he said.
Old 08-15-2010, 07:42 PM
Can someone give some more specific instructions, Last thing I need to finish. If you crank car it seems like it would fire right now witht thje clutch pedal to the floor and no wiring done.
Old 08-15-2010, 08:45 PM
Gingervitis Addict
slow67's Avatar
Cut the 4 wires going to the clutch switch. The 2 wires that go to the brake pedal switch , just crimp/solder those 2 together. All they did was cut the cruise if you pushed in the clutch. The other 2 wires (that don't go to the brake pedal switch) extend both wires to the shifter. Connect each wire to 1 side of the NSS (Neutral Safety Switch). The NSS is now doing the same job as the clutch switch.
Quick Reply: How to wire up clutch pedal for auto swap?
