th400 transpan selection
Old Aug 18, 2010 | 10:26 PM
trans2000am's Avatar
Default th400 transpan selection
What after market trans pans for a th400 is everybody running an do you like it an why? any issues?
i just got a new summit magazine in an seen a derale pan which has a drain an also temp sensor port also for 120ish they claim to cool almost 50degrees
an would you go with a deep pan for a street car?
thanks
Old Aug 19, 2010 | 09:16 AM
72blownvert's Avatar
I would go with a trans specialties aluminum pan because they fit perfect and i like the fact that they use a gm pickup tube and hardware for the placement of the filter. B&M is nice also but they are a little pricey.The derale is ok but the tubes take up space and therefore it does not hold as much fluid also they are made from stamped steel which is not as durable as aluminum plus i have yet to see a 50 degree drop just from the pan alone.
Old Aug 19, 2010 | 04:42 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I've got a Derale on my TH350
Old Aug 19, 2010 | 05:16 PM
how do u like it? how is the fitment?
Old Aug 19, 2010 | 07:11 PM
Z28/2002's Avatar
Couldn't tell ya, I bought it and put it on then I pulled the motor out.
It fit good and has a +2 quart capacity and a 1/8" port for the sending unit
Old Aug 19, 2010 | 08:35 PM
Detroit Gearbox's Avatar
Just buy the galvanized gm/delco pan, pick up, bolt & spacer. Its under 90 bucks, never leaks, never rusts or oxidizes and all the spacing/filter support is proper.
Old Aug 20, 2010 | 08:31 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
we have the aluminum deep pans for a 400 and they come with the bolts and the GM filter tube and filter spacer w/bolt for that as well. The cost is 104.99
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Aug 20, 2010 | 01:45 PM
where the best place to buy?
Old Aug 21, 2010 | 07:31 AM
FLT's Avatar
FLT
See the comment below on the TSI pan. For a little bit more you can have a nice aluminum pan. I have installed many of these and they are a nice piece.
+1 on the TSI pan. Also I agree on the Derale pans. Not sure if I'm convinced that the advertised drop is really true. Plus they seem to be made of thinner steel than a factory pan. I personally would use a factory pan before one of these but my first choice is the TSI pan. Vince
Old Aug 21, 2010 | 12:42 PM
thanks for all the info i just want a nice pan that with hold more fluid an can take the street abuse an liked that the derale already had a tap in it for a gauge
Old Aug 22, 2010 | 01:51 PM
Yea, I went to look at them online but their web site been down for the last week +. I cant stand some pans that they don't machine properly for the bolts to come on and off or having to f*uck with the pickup tube/bolt & spacer. just a pet peeve
Old Aug 26, 2010 | 03:21 PM
1999FirehawkLS1's Avatar
This TSI pan looks like what came on my Abruzzi TH400 and I hate It!!!! stupid pan w a 1/8 drain plug that u cant even get the plug out cause it uses a 1/4 allen wrench and the allen wrech key way is not even 1/4 deep.......this is the thrid pan iv seen like this that u cant even get the drain plug out!!!!
Old Aug 26, 2010 | 07:26 PM
[QUOTE=1999FirehawkLS1;13784317]This TSI pan looks like what came on my Abruzzi TH400 and I hate It!!!!QUOTE]
Ive yet to put one in my hands. Ive always welded a nut inside the pan and use a 1/2 engine oil dan drain nut w/viton sealed washer.
Can you just retap the pan another size?
Old Aug 26, 2010 | 07:45 PM
INTENESS's Avatar
I have the deep BM pan comes with a temp sender tap already in the pan.Fit is great I drive my car on the street and its been fine.
Old Aug 27, 2010 | 04:14 PM
[QUOTE=Detroit Gearbox;13785396]
I would but its cast alum pan so im going to have to machine the sucker myself I just hate buying brand new stuff and haven to redo it like always w car parts...
