th350 problems now :(
So i've had this rmvb th350 sitting here for a month and a half now with a new converter and I finally got a day off of work to do the swap in my driveway, yay! So 3.5 hours later I've got the old th350/converter out and the new one up and bolted in. I got a GREAT Madman dipstick so now I can easily fill the tranny. I put 1.5 quarts into the converter (8-inch) before attaching it to the tranny, and topped off the tranny with 5 more quarts. I have the shifter linkage perfect, you can easily feel each detent. I start the car on the 4 jackstands just to see if indeed it works, and I can tell that something is wrong with reverse. You don't feel the rpm drop at all when reverse is engaged. With the shifter in "R" with the car up in the air, the tires will barely move. You have to rev it a little to give them some momentum. Totally opposite in the forward gears. It engages first and rocks the whole car "WHAM". I shut the car off, disengage the shifter linkage and reach down and click the lever by the pan into reverse. I start the car and it's the same thing, reverse barely moves. Check the fluid after going through each gear and it's fine. Put the shifter into "R" and reattach the linkage and it's dead-on.
What would cause reverse to be so weak? The thing is brand new?
does it have a transbrake?
Greg
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
LOL, yep. I feel like such an ***. I had no idea it needed the brake button applied in order for it to go into reverse. I called my builder and he told me to do that. I'm about to head out and wire it up right now.
