Is the 4L80E worth the extra weight?
I throwing together a swap for my '84 Monte Carlo SS & I'm trying to choose a transmission. My original plan was to put in the 6.0L LQ4 & a 700R4 trans that I had sitting around. Come to find out, that 700 has a cracked bellhousing. So I have someone offering to sell me an 80E for $400 with low mileage. My only concern about that is how much they weigh. I'm going off memory, but I remember the 80E being quite a bit heavier than say a 60E. And I remember the torque converter being heavier too.
Part of the reason I'm being weight conscious is because I'm going to run the iron bottom end from the LQ4 which is already a 85lb. gain from the aluminum blocks. I have another 700R4 but it needs an overhaul. So what would you guys go with, the low mileage 80E, find a low mileage 60E, or overhaul my other 700, & why?
Thanks in advance for any opinions.
~Ryan
and can stand much more abuse.....
if you didnt want od, the 350 or 400 would be ok
i have the cast iron 6.0 block and 4l80e in my chevelle, love it, dont really notice the weight, but its a street car, so the weight doesnt matter anyway
if your gonna run the 6.0 with a computer (FI) i would get a comp ECU/harness, cut out what you dont need, it could run everything
dont forget you would need to hook up the TV cable on the FI, but i think Street & Perf might have a bracket-are you gonna use the truck FI (tall) or LS6 intake
a lot of guys have run the 200r4 trans, another option
IF you do not care bout the O/D then TH400.
So where should I look for a lighter performance converter for the 80E?
Oh, and my plans for the LQ4 that I'm throwing in will involve a turbo or supercharger in the near future.
