TH400's
Any special bits needed to fit them?
Only need to get a torque converter that fits. Any converter shop can do this if they have a few measurements.
I had my converter from my 4L60E adapted to fit.
Current shifters a B&M Mega shifter which I think should be sufficient
I think Dominator have done a converter for Howquicks LS!/TH400 setup you could try them too I 'spose.
3500 stall is good but it depends on what you want from your car and what camshaft/diff gears etc you are running.
When you talk to the converter dudes tell them about your setup and what you would like and they will have good recommendations.
A shift kit and good internals are all that's needed on a TH400 if you are after a street/strip car ....plus you get the bonus of having a normal operational auto.
I wanted a box that can launch 3800 lb's on a trans brake with 700 hp N/A and a couple of hundred extra on the gas.... TH400 fits the bill.
Besides, the transbrake makes it all worth while!! MUWAHAHAHAHAHAHA!!!!!!
