Install new flexplate along with aftermarket stall?
Old 02-19-2011, 01:28 PM
senicalj4579's Avatar
Originally Posted by 1gt2nv
I would just replace it while in there. I found one on ebay for like $70. Think it's the one 01ssredA4 is talking about. I'll be getting that when I order my ss4000 stall!!!
Cant be the one hes talkin about. Can I have the link please?
I actualy talked to dave at yank and he said they would help me out. I guess they may have some.
Old 02-19-2011, 05:17 PM
01ssreda4's Avatar
Yeah that CAT Power floats around at a lot of places and gets re-badged as other brands as well. However, it is NOT on ebay anymore.
Old 02-19-2011, 11:02 PM
I went right to power cat and I see they have them for 75+shipping. Im gonna see what dave from yank recomends me on mon but if not ill grab one from power cat.
Old 02-19-2011, 11:20 PM
01ssreda4's Avatar
I think Dave throws in the CAT power flex-plate for free or cheap when he is running specials. If he anyone says they have an SFI flex-plate or $150 brand new or less its the cat power. All others are $200+.
Old 02-20-2011, 12:39 AM
Anthony Williams's Avatar
SFI rated is the only way to go, go directly to cats web site. I am running one of their flexplates with no issues. You really don't want to loose a flexplate on the run. It's just cheap insurance.
Old 02-20-2011, 03:02 AM
01ssreda4's Avatar
For anyone that wants to know, yes the Cat Power is a chinaman flexplate, however, the SFI rating is legit. I checked their website.
Old 02-20-2011, 03:58 AM
odarabla's Avatar
The stock flex plate can handle a lot of power. I was running high 10's on mine with no issues until I switched to the th350 tranny. The difference between the years is that from 98-00 the flex plates had both SBC and LS style bolt pattern and the newer ones (01-02) only had the LS style bolt holes tapped out. Now the SBC ones were there you just had to drill them out. I used the TCI flex plate as another option but to each his own..
Old 02-20-2011, 07:12 AM
I did alot of searching and what I found was the TCI wasnt recomended by yank but the thing is the poster never gave a reason so wtf knows?! But also I guess the powdercoat on that TCI isnt good and bolt heads need to be shaved down or they hit the block. I did a **** ton of searching and found alot of mixed answers. Most people seem to be running the TCI and POWER CAT.
Old 02-20-2011, 12:19 PM
02sleeperz28's Avatar
I have a TCI flexplate haven't installed it yet.
Old 02-20-2011, 07:50 PM
sheikss's Avatar
I have the TCI with a Vig stall. I bought the arp bolts and they weren't long enough so I went to the hardware store and got me some grade 8's. I think I had to go with a 3/4" long bolt. Had I went with a stock flexplate I would have been able to use them. For what some SFI plates can be bought for it seems like a good investment. I do have a tendency to over build things though. I had to use an 1/8" shim to get the converter spacing correct.
Old 02-21-2011, 11:18 AM
Just a little update. I talked with Dave@yank and I guess they used to get their FPS from Cat power. Says they went out of buisness. Anywho, I was recomended the trailblazer FP its not sfi rated but its stronger and should be a great fit. Should be fairly cheap to.
Old 02-21-2011, 11:21 AM
  #32
01ssreda4's Avatar
Nice find
Old 02-21-2011, 12:18 PM
  #33
HAHA well, just ordered the upgraded FP from dealer. Not as cheap as thought $165 but I trust its much better than my stock 01-02 and should fit with stock bolts. Price must have somethin to do with living in CT everything is expensive as hell!
For anyone doing a search, part # for this is flexplate is #12602448
Old 02-22-2011, 09:22 PM
  #34
tording99Z28's Avatar
Originally Posted by 01ssreda4
The stocker is crap (thin and weak). Anything aftermarket is an improvement. Im running the CAT Power. Its heavier then stock but a hell of a lot stronger. Its about twice as thick as the stocker. They usually run about $70 shipped (ebay) and are SFI rated to about 13K rpms. Stock bolts will work fine.
Running the CAT power here too. Much thicker and Beefier and its SFI rated for like $70. Can't beat it.
Old 02-22-2011, 10:15 PM
  #35
Default Heres the upgraded FP from GM I just picked up today.
Old 02-22-2011, 10:25 PM
  #36
Heres the CAT one. Still in business as far as I can tell and much cheaper than that.
http://www.catpep.com/searchengine/s...00&parttype=14
You would want FP-346
Old 02-22-2011, 10:32 PM
  #37
tittan1500's Avatar
Originally Posted by senicalj4579
Everything lined up great? Bolts came with it? Bolts were right length?
the install went smooth I had no issues.
Old 02-22-2011, 10:39 PM
  #38
Thats what I told Dave at yank but he said hes been trying to order from them the last few months and they are out of buisness. I also called tsp to see if they had it in stock but they didnt have any either. So who knows. Either way I got the upgraded piece.
Old 02-23-2011, 04:17 AM
  #39
ricekiller28's Avatar
just got the Cat flexplate last week, just go to ebay motors n search ls1 flexplate, u will come across it. 60$ plus 15$ shipping. Very impressed with it.
Old 02-23-2011, 08:02 AM
  #40
It isnt there anymore. If you still see it put the link here. But like I said, I already bought one.
Quick Reply: Install new flexplate along with aftermarket stall?
