weird problem...any suggestions?
Old Sep 23, 2010 | 10:03 AM
02_Z28_G's Avatar
Default weird problem...any suggestions?
I have an 02 z28 and i have noticed that when i drop the car down into 3rd at a cruising speed the transmission kind of shudders unless i'm at WOT. 2nd gear is fine and i have no problems it seems to just be 3rd. any suggestions as to what is causing this?
Old Sep 23, 2010 | 03:38 PM
02_Z28_G's Avatar
anyone...?
the only things i have read so far have been something to to with the converter "shuddering"...?
Old Sep 23, 2010 | 08:20 PM
performabuilt's Avatar
LS1Tech Sponsor
The only thing different is you have overun now if you have a cam you may get somewhat of a shudder trailer type feel
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Sep 24, 2010 | 10:55 AM
02_Z28_G's Avatar
i don't have a cam yet, only the mods in my sig
Old Sep 24, 2010 | 08:46 PM
joecar's Avatar
The TCC is locked in 3rd, and is unlocked at WOT and also in 2nd)... so yes it can be that.
Are you sure its the trans/TCC and not the engine misfiring...?
Old Sep 24, 2010 | 10:44 PM
DiabloFormula's Avatar
TCC reg in the pump or converter. A shudder is a shudder, which usually means converter or something that has to do with the converter, electrical or mechanical.
Old Sep 25, 2010 | 10:42 AM
02_Z28_G's Avatar
TCC?
i know for sure it isn't the engine
Old Sep 29, 2010 | 03:16 AM
NXZ28's Avatar
Originally Posted by 02_Z28_G
TCC?
TCC = Torque Converter Clutch
Old Sep 29, 2010 | 09:44 AM
02_Z28_G's Avatar
ok thanks
so how would i go about diagnosing this to see if this is the problem? or would just replacing the converter be able to fix this?
Old Sep 29, 2010 | 09:57 AM
NXZ28's Avatar
How many miles have you put on it? My Fuddle would shudder when it went into lock-up at around 40-45 mph. I had a new tune put into the car with the lockup adjusted to 50mph in third gear. Anything sooner and it would shudder a little during lockup. Is the computer throwing any codes?
Old Sep 29, 2010 | 10:07 AM
02_Z28_G's Avatar
i'm not the original owner so i'm going with the odometer, 144k.
i ran the codes a while back when i was having a few problems(ended up needing new 02 sensors) and nothing ever came up relating to the transmission. The car has yet to get tuned also so if it's a tuning thing i could probably get it adjusted then also
