whats a th400 eat
Old Oct 13, 2010 | 09:07 PM
bad6as's Avatar
Default whats a th400 eat
dont say 25% or 15%. im looking for a hp number. if i want 800 hp to the motor what will that do to the wheels? 700 or 650?
Old Oct 13, 2010 | 10:06 PM
mike13's Avatar
It's going to be tough to get a good answer, mostly because of the efficiency of the torque converter.
Old Oct 13, 2010 | 10:40 PM
Carter01's Avatar
what mike13 said. I swapped to a th400 from a 6sp, also took off my cats during this time, added a 9 inch with the same 410 gears but a spool and made 7 less rwhp. Same dyno, same tuner, same software, almost same weather. FTI stall... Pretty close to apples to apples comparison.
Old Oct 14, 2010 | 09:14 AM
slow67's Avatar
Gingervitis Addict
It depends on how fast you try to accelerate it....also the converter will likely eat more than the trans.
Old Oct 14, 2010 | 01:49 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Converter will play a big part in what is loss.
From personal experience, we had a guy, local, had a 98 T/A with a Rapid Motorsports 383 which made around 550 rwhp to a 12 bolt and 6 speed. The kid swapped out the trans and a looseish 4500 converter (set for nitrous). On motor the car dynoed 480 rwhp, a good 70 HP loss over the 6 speed.
Car was tuned and work done by Eastside Perf out of Wallingford CT, former record holder for the LSx Nitrous Record, so they know what they are doing.
One other thing I might add is the car got a whole lot faster once the Auto went in.
Old Oct 14, 2010 | 01:53 PM
bad6as's Avatar
right so.... say im looking to make 800 flywheel horse power. if i dyno 650 to the wheels i lost 150hp. i dont want to push it to far but i would like tho get close to a certin flywheel hp. but need to know when to stop on the dyno.
so if i dyno say 700, we could figure 850 to the motor?
Old Oct 14, 2010 | 05:28 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Sounds to me like you want a dyno queen
Old Oct 15, 2010 | 07:27 PM
1999FirehawkLS1's Avatar
F-Body plus stalled Auto= good track car not HP queen..
^ Agreed
Old Oct 15, 2010 | 10:14 PM
bad6as's Avatar
dyno queen? lol no. i dont want to push the motor past 1100hp. so if the th400 eats 200hp. then at 900 wheel ill stop turning it up. if it eats 350 ill stop 750.
do you all understand what im saying? i dont give a f what it puts to the wheels. im using the dyno to get a number, that i can convert in to flywheel numbers. and i use the flywheel numbers to aprox figure out e/t and mph
Old Oct 15, 2010 | 10:22 PM
Gordon0652's Avatar
When i am thinking of an automatic build i always say 100hp because if it uses less than 100hp you'll be happier!
Old Oct 15, 2010 | 10:33 PM
bad6as's Avatar
well from what ive researched 18psi will get me aprox 1k flywheel. i think.
so ill hit 18lbs and see what it does, just wanted some input from others
Old Oct 16, 2010 | 12:56 AM
TurboAv's Avatar
6-speed dyno:
Same motor after TH400 and FTI 4000 stall:
Old Oct 16, 2010 | 08:34 AM
Gordon0652's Avatar
About 26hp, does not seem like a bad loss esp with the launches you will get with that automatic. And i bet that TH400 is less efficient than a 4L60e
