Trying to figure out my shift extension. what rpm when going into 2nd stock?
It looks like mine drops down to about 4700 rpm on a full throttle run when it shifts into 2nd gear.
Just checked my logs... with my stock verter shifting at 6100 1-2 rpms went down to 3650. Shifting at 6500 went down to 3900. With the circle d its 5100 rpms . stock 3.23 gears
BTW you can not use your stock tach to tell.... The stock tach is far to slow moving. If your using your tach to see where your shift extension is its very possible its 300-400 rpm below that...
